Question about Quantaray AF 70-300mm f/4.0-5.6 High Speed Auto Focus Zoom for Minolta
I use thais lense on a cannon rebel xti and it takes black pic
When i turn on the cammera it gives me a error 99 code it tells me to turn off and then turn on the cammera it only does this when i use my 70-300 lens when i mess around i can get it to work only on manuale focase and when i take the picthure it is all black
    Scholar:
  • 170 Answers
Error 99 is one irritant in many Canon SLRs. In general, it means there is some problem with the contacts. So try cleaning the electrical contacts of the body and lens with a pencil eraser.Please take care to hold the camera upside down while doing this so that the residue does not fall inside. Also take out the battery and clean the contacts. Now re-attach everything and try taking the image. Also check if your lens has an aperture ring and aperture lock. If so, lock the aperture ring at the minimum aperture. If these do not solve the problem, try updating the firmware to the latest one.
Posted on Dec 13, 2009
Canon rebel xti only takes part of a picture
The problem is in the lens housing, replacement the only option. Not cost effective for repair, cheaper to replace.
Mar 12, 2012 | Canon Cameras
1000d error code 1
user manual say its a communication problem between the camera and lens. The suggested solution is to clean the contacts.
Jan 18, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My cannon rebel eos DS6041 displays error 99 when
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Jun 01, 2010 | Canon Digital Rebel / EOS-300D Digital...
It says error 99 its a rebel xti
problem in lens repair it a F PCB IS BROKEN
Nov 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Error 99! Wont' take picture, the message states
Go to the www.canon.com website and find out what Error 99 means. ted10
Apr 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I have a Cannon EOS Rebel XTI. And I use a white
check the white balance setting and keep the one that corrects it ...... try manual white balance if you have the knowledge
Mar 06, 2009 | Canon PowerShot S5 IS Digital Camera
I have a Cannon Rebel XTI and i keep getting err 99
Make sure your firmware is up to date. The current version is 1.09 which did address a problem with live view that could cause error 99.
Here's the link http://web.canon.jp/imaging/eosd/firm-e/eosdigital4/firmware.html
Also try removing your lens and putting it back on. Sometimes it is a bad connections between the body and lens that can cause this error.
Jan 27, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99
WHAT IS THE SOLUION OF ERROR 99
Aug 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Quantary Tech-10 75-300mm use with Canon Rebel XTi
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Mar 12, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Quantaray AF 70-300mm f/4.0-5.6 High Speed Auto Focus Zoom for Minolta Logo
128 people viewed this question
Top Quantaray Cameras Experts
Steve
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
