Question about Stoves Ovens
How do i set the clock on a stoves 700gr mk2 double gas cooker
My stoves 700gr has stoped workin can you pls help
Posted on Dec 14, 2009
SOURCE:
How do i set the clock on Stoves cooker model number GL 716
if I could see the panel I might be able to tell you ours is press clock then the + or=- buttons
Feb 02, 2017 | Stoves Ovens
Where can I get a manual for a Stoves 700GDO Mk2?
Go to the manufacturer's website. They should have one you can download.
Oct 08, 2014 | Ovens
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
Lost handbook for cooker. Cant remember which
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
Nov 27, 2009 | Stoves Premier 900GRa Gas Double Oven
How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
Aug 02, 2009 | Stoves 720EF Electric Double Oven
Need to adjust clock setting on Stoves 900 GDO Stoves 900 GDO gas double oven
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Mar 06, 2009 | Stoves Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Ovens Logo
273 people viewed this question
Top Stoves Ovens Experts
Marvin
Marvin
Steve F
Are you a Stoves Oven Expert? Answer questions, earn points and help others
