Question about HP Photosmart C6180 All-In-One InkJet Printer
My printer is booting, then shutting down, then booting again. I tried to hard reset it by unplugging everything and then pushing # and 6 but his failed to change anything....
  • david_cox91 Dec 13, 2009
    Yes, this worked. Thank You!
    President:
  • 3,278 Answers
Hello, David.
Even though you have performed the hard reset procedure, give this a try:
1. Before pulling the power connector, depress and hold the # and the 6 and them hold down from here on;
2. Pull the power plug, Count to 30 before proceeding, with # and 6 still depressed;
3. Reinsert the power plug with # AND 6 still held down until machine powers down, about 30 more seconds or so.
4. Machine eventually resets (turns off). Please note:. ALL settings have been erased including fax and wireless, so you need to set them up at the end, below. OK to release # and 6 now.
5. Press power button. Will come up quickly to the do-not-unplug-power warning, hit OK. Machine will now go through 2 minutes of initialization.
6. If you use wireless, do the wireless setup from NETWORK menu and print the network report which confirms connection as well as that it can print.
7. Set up FAX if needed.
Hope this helps.
Posted on Dec 12, 2009
  • NinaE Dec 13, 2009
    You are welcome. Thanks for using FixYa.
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
How to reset a NAD L54 DVD reciever?
This is the technical solution, you have to open the unit:
Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.
The unit will then boot up in factory default.
Henrik Pedersen
Jul 20, 2012 | NAD Audio Players & Recorders
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
The ink system not working
here. try to reset your printer. this will clear annoying error displayed on your printer
1. Remove all cables
2. Unplug the printer power.
3. Press and Hold down # and 6 on the keyboard.
4. Plug the power cord back in.
5. Then release the buttons....after successful boot operation, try to print.
If that did not work.. you can also try this.
1. Press/Hold down the HELP and OK button..then unplug printer..release the button
2 Press/Hold down the HELP and OK button again..then plug the printer back in. Just Press and hold down the button while you wait for the printer to turn on (it could take a minute)
3 Now release the buttons and power it back on.
4 Error message will be displayed “improper shut down”
5 Press OK to reset the printer
6. Press both HELP and OK button again to start the resetting procedure of the printer.
Now try printing again...
If you find this very helpful..please rate this solution and vote on this on the YES below....thanks..
Jun 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart C6180 All in one printer will not start although live
Strange because I have the same issue, and I've had this printer for over 3 years but the problem just started about a month ago.
I reset the printer by: 1) Unplug power to the printer 2) Hold #6 on the keyboard 3) Plug power cord back in while holding #6 Eventually (10 seconds?) the printer will shut down. Once it does, release #6 and power up the printer again.
Warning: This reset all the configuration settings.
This works for me, but there is still an issue because I have to repeat this every time I turn off/on the printer.
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
How do i re boot my hp office jet
Unplug the power cable from the back of the printer and put it back in
Oct 23, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Problem booting into Windows.
This could be a hard drive problem. The hard drive is looking for the boot sector on it, but the boot sector is broken. Computer shuts down and tries again but your hard drive can't find the boot sector so it shuts down tries again etc.
Hank
Sep 24, 2009 | ECS C51GM-M Motherboard
C6180 All-in-one: On-off loop never stops
while the printer is on remove the power cable from the printer then press # and 3 on the printer together and then while pressing the buttons insert the power cord n then leave the buttons
if still problem persists then try the same thing by pressing # and 6
Jul 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Hp2410 unable to operate
Cleaning your appliance may very well take care of your problem. But if not make sure the drivers and the software have been installed. If they appear to be installed then uninstall them and restart your computer and reinstall them. If you have the same problem then take to a qualified service center.
Aug 06, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
