Can the cpu fan speed be regulated or is it always on "high"?
  • 63 Answers
No you can change that, you have to restart the computer and press delete button untill your settings screen comes up and the setting is in there, not sure where again but its not hard to find, cheers
Posted on Dec 12, 2009
Why is the cpu fan always off on my dinension E510
Fan defective
Fan not plugged into proper connector
Computer not warm enough to run fan at high enough speed to hear.
Jul 03, 2014 | Dell (W2562) Motherboard
Tip
CPU Fan Speed high
What Could be happening inside when you hear the cpu fan running at a high speed always ?
Ever thought about it ? Ok let me give you a clue on this. To understand this issue you need to understand how the hardware works on various situations.
Check the Heat settings in bios and look for the variance.
Bios can instruct a CPU fan to run faster only when there are critical lssues of heating.
The CPU starts running on a realtime 16bit more known as SMM mode.
This is a feature which is inbuilt to support the continuous performance of the Processor even while temperature level rises.
The instruction is moved through the Bios, and can be a bios related issue.
Worst case, Flash the Bios once for all and the issue will be solved.
If its a very old system flashing the bios could be also a problem, still you can seek the help of a Hardware Engineer to get this accomplished.
on Feb 13, 2010 | Computers & Internet
How to compaq 6400 bios slow
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
Hope these tips will help.
Feb 06, 2014 | HP Compaq nc6400 Notebook
Half on hour my automatically turn off
Solution for this problem:
Jan 18, 2014 | CMB T43 750 Notebook
Fan runs hard computer is slow hp compaq nc6000
- Shut down your computer at least two hour a day.
Jan 05, 2014 | HP Compaq 6735s Notebook
Its beeping and beeping and beeping
- Shut down your computer atleast two hour a day.
Aug 04, 2013 | Gigabyte GA-H61M-DS2 Motherboard
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
Why is my dell optiplex GX260 CPU fan is very fast ?
Usually the fan regulates its own speed (or rather the BIOS does) in relation to the current heat, you may have heat/environmental issues, or power issues. However I would first check to see that the fan speed isn't statically(permanently) set to a high speed. You can check this in the BIOS, as the machine starts up it will flash a small message ( For Setup or For Setup, something like that), hit the stated button to enter your BIOS, under 'Thermal' or 'Hardware' you should be able to find fan speed.
Aug 22, 2011 | Dell OptiPlex GX260 PC Desktop
Cpu fan running at high rpms
Are you sure there is enough thermal jel between the new cpu and the fan? If not, fan could not get enough heat and constantly tries harder. That thermal jel creates a better environment for the heat conduction so that fan could do less job and take out more heat at the same time. Hope this will help.
Apr 14, 2009 | Computers & Internet
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
19 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
