Question about Sony KP-51WS500 51" Rear Projection Television
Colour conv. mode and magic focus does not adjust convergence.
Hi guru.two convergence ics replaced voltage checks ok parts checks ok. yet the blue, red and green colours connot be adjusted. nor the magic focus at front respond. but doesnot adjust the colours. i am a technician whats the solution. can you down load me a copy of the convergence circuits.
    Sergeant:
  • 380 Answers
Did you happen to check the pico fuses? How about the B+?
Posted on Dec 13, 2009
Testimonial: "the b+ voltaes pico fuses resistors and two conv.ics checked & replaced. yet colour conv.doesnt adjust.whats the solution mr guru."
  • Paul Dec 13, 2009
    There is a diode and some resisters in the power supply. I don't know the designations.
Sony tv kp51ws500. 3 colour off centered.2 conv.ics replaced componant and voltages ckecks ok.yet convergence doesnt adjust.magic focus doesnt adjust colour. whats the solution.
perfect focus is what this uses-magic focus is what it is called in the Hitachi sets.
If it is KP51ws500 did you check the two 5 amp pico fuses on the other board---the power supply board?
let me know what you find and I will help you--I have fixed hundreds of these sets.
SD TECH
Dec 16, 2009 | Sony KP-51WS500 51" Rear Projection...
Blue lamp is not in focus
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi projection tv 53SDX01B is out of focus how do you reset.
if magic focus will not correct convergence problem look in the customer menu for the word CONVERGENCE---IF BLUE WILL NOT ADJUST IN some direction, one of the two Stk-392-110(or 392-150) convergence Ic chips are bad; you may also find some burnt or discolored resistors behind them----this kind of problem is usually fixable right in your home; if you need direct help;;;
etower.766@netzero. net
If this was helpful I would appreciate a vote from you here.
Aug 14, 2009 | Hitachi 60V715 60" Rear Projection...
Convergence ICs
Well if you are not a repairman you should not do this kind of job yourself.
If you decide to service your TV, remember to keep it unplugged for one hour before working on it.
Check this link here to find sellers for the kit and illustrated procedures.
Here I am reporting convergence procedure from website above.:
" Manual Convergence for the Hitachi
1) Receive an NTSC signal.
2) Press Magic Focus to begin magic focus
3) Press magic focus again during the magic focus process to get the ?stop? screen
4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
the service grid (64 point grid)
5) When you first get in here? I believe red is the selected color by default (it is flashing).
6) To choose other colors to converge, use the following buttons on the R/C:
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
(a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
(b) Use thumb stick to move the convergence point color.
** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
better this way. There are some other posts also recommending using binoculars. I think it?s great that people
suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
This is highly suggested unless you have geometry problems.
9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
line between the points will not straighten out (it bends between the points). To fix this, the manual recommends
going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is
also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in
(13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press ?0? 5 times
3. (13x9) Press ?ANT? 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence
as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed
to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write
displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
windows appear during this operation. It takes about 30 seconds or less.
18) When green dots appear, initialize operation is finished.
19) Turn power OFF.
21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
to make sure the magic focus still works (and that you did the last few steps properly)"
Perform full convergence procedure before replacing ICs.
To know if an IC has blown you should test the small fuse at the base of the IC.
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Magic Focus
You will need to replace both convergence ICs STK392-110 you can get replacement ICs and they come with free instalation instructions with pictures and they also offer free tech support with online instant messageing in case you need additional help, and they also ship to anywhere in the world. Heres the link.
http://servicemanuals.vstore.ca/
May 28, 2008 | Hitachi 46F500 46" Rear Projection...
Conv problems with no pic has sound
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Apr 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Hitachi 53UWX10B 53 convergence color lines dont move w\RC
After replacing IC's, double check the solder connections for bridging or no solder on pin(s). Check all bias resistors (low ohmage). Make sure you have your VCC voltage, should have a positive/negitive voltage of about 24 v on each IC and +38v.Also, make sure all cables are plugged in and fully seated
Note: All bias resistors are very low ohms eg; 3.3, 1.8, 2.2 make sure correct value, very important.
If can't adjust still CPU digital convergence board (near ic's) shielded may be defective.
Feb 23, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Magic Focus does not work.
Convergence issues usually resolved by changing convergence output amplifier IC's.....Original STK392-110 should be replaced
with upgrade Stk394-160E Hitachi part # CZ 01341,change both
for reliability.....check B+ feed resistors for over-heating....T.
Feb 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Jan 13, 2008 | Hitachi 43FDX01B TV
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
