Question about Juicers
Lots of shaking - Juicers
    Scholar:
  • 66 Answers
If your washing machine is shaking you most likely have a leveling issue. The machine should have two adjustable front legs that can be screwed in or out. By using these and making use of a simple level you should be able to stabilize the machine. Also make sure that when you load the machine you evenly distribute the clothing around the agitator. Make sure not to group all the towels on one side of the machine, that sort of thing.
Posted on Dec 12, 2009
I took my juicer apart and now I am trying to re assemble it but I don't know where the springs go. Please help
they attach to each side of the metal bar. i threw the springs away because i couldn't figure out where they went, and now the unit shakes like crazy :) but i read up on it and found out the springs go on each side of the bar i think. 50 bucks will replace the bottom part of the machine (base and motor) https://www.unitycart.com/pjss/parts/parts_classic.asp
Jul 26, 2011 | Jack Lalanne Power Juicer 250 Watts
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
Mar 05, 2011 | Omega 1000 Juice Extractor
My #6001 juicer ( old!!) will make a very loud sound even after only 3 carrots.. causing me to stop and clean out pulp.. even may shake more than usual... so am thinking it should need an overhaul??? I...
No overhaul. These juicers do not eject the pulp and are subject to vibration especially if you
install a new blade. I've had one for 21 years and get by using a worn blade which I sharpen
with an electric drill using a small bit.
Mar 03, 2011 | Acme 6001 Juice Extractor
When I start juicing, the machine works beautifully. By the time I am finishing the machine is making a very loud noise and the machine shakes. Any idea what is going on? The machine is less than a year...
It's going out of balance like a washing machine with the clothes
on one side during the spin cycle. I've had mine for 20 years and
have not completely mastered the balance problem. Just try to
feed produce as slowly and as evenly as you can. If it really starts
to vibrate too badly, turn it off immediately or the blade will jump
and cut the feed chute.
Jan 15, 2011 | Acme 6001 Juice Extractor
My Omega Juicer 1000 shakes violently and the entire machine rotates unless I firmly hold it or turn it off. It's been in the closet for good seven years before I took it out and started using it. It's...
Make sure the bottom of the feed chute is not damaged. If it,s chipped or scored, try filing
it down level as best you can. Then with the juicer fully assembled, unlock the set screw
on the center of the bottom and turn it clockwise until the chute contacts the blade, then
back it off a half turn and lock it down. By the way a dull worn blade will produce less
vibration. I'm assuming the lid is plastic.
Sep 28, 2010 | Omega 1000 Juice Extractor
Why does my supreme juicerator shake and make noices
the rubber banding on the bottom of the shredder disk gets worn over time and you might need to buy a new shredder disk. I was experiencing the same problem (the juicer was vibrating at an odd speed,shaking and the sound of the motor was distressed, when the plunger was inserted to push down the veggies it was banging and making an awful noise) replacing the disk solved the problem - good as new.
Sep 28, 2009 | Acme 5001 Supreme Juicerator Juice...
Breville Juicer not juicing properly
MY WIFE HAS ONE AND IT'S LIKE A LOOSE CANNON. IF IT IS LEAKING FEED IT
VERY SLOWLY.
Jun 29, 2009 | Breville Juicers
How do I remove the filer cone for cleaning?
I suggest pick it up by spout & other side of bowl & shake a little & it should release from the base unit
Jan 06, 2009 | Breville Juicers
Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
Jan 18, 2008 | Acme 5001 Supreme Juicerator Juice...
Juicers Logo
42 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
