Question about Canon imageRUNNER C3200 Copier
Canon ir7105 finisher unit is not working..! - Canon imageRUNNER C3200 Copier
  • 1 more comment
  • atif_shahji Dec 12, 2009
    no its not giving any error, just giving message on display pannel, "finisher unit can'nt use"
    and since 3 days i have also an error E110..
    i check possibilities for removing error, but failed.
    can u please guide me regarding this.?
  • Ian  Auret
    Ian Auret May 11, 2010
    Hi Can you tell me wat is the problem with the finisher.Is it give any error codes?
  • 318 Answers
The finnisher is only in disable by a a disable funcktion that switch the finnisher off.It just need a reset in the service mode.I am not alowed to give service info on the net.Ask your local service centre to clear the funcktion for you.You dont have to replace the finnisher.This is normally a paperjam or a opstical that prevented the trays to move up and down.Then the finnisher go to disable funcktion
Thanks for you support
Posted on Dec 13, 2009
    President:
  • Canon Master
  • 1,447 Answers
Change it or replace by an copier expert.Who live in your area.
Posted on Dec 12, 2009
2 Suggested Answers
  • 39 Answers
SOURCE: i found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
Posted on Dec 18, 2009
202-001 what is problem this error modle no ir7105
This is a scan problem, Please check: scan switch, scan motor, or image processor board.
Thank you.
Jul 22, 2014 | Canon Gpr19 Ir7105/7095 Black Copier Toner
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Apr 15, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir7105 error codes 000602
TRy this link. Reading similar errors, similar machine = hard drive error. can ir7200 602 001 Archive Copytechnet com
Apr 09, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
E000225 0001
error code E000225-0001 on iR7105 .what can i do to remove this code?show me the steps.
Jan 23, 2014 | Canon iR3035 Copier
Canon ir7105
with the copier on press the system monitor button and see if you can see the complete machine with the all accessories attached
then you do is go to the back of the finisher and check if the silver terminal connector is connected properly
i have found that the pin inside the connector gets pushed inside
you can pull it out with a small needle nose pliers
reconnect everything and power up the machine
if you need more help after trying this let me know i will guide you through the service mode
mickey@mnmsllc.com
Oct 24, 2013 | Office Equipment & Supplies
PAPER JAM
Open and pull out crumpled paper to clear it.
Sep 26, 2013 | Canon Gpr19 Ir7105/7095 Black Copier Toner
I found error in canon ir7105, and i checked
Dec 14, 2009 | Canon imageRUNNER C3200 Copier
Canon ir7105 photocopier
are you talking about the username and password to login to the canon tech support page @ support.cusa.canon.com? If so, this is for certified technicians only. I would NEVER give my personal info for this, but, if you present me with your problem I will get you the answer you need. I am very familiar with the ir7105.
Mar 07, 2008 | Canon NP 6551 Black and White Copier
Canon imageRUNNER C3200 Copier Logo
1,167 people viewed this question
old marine
old marine
