Question about Little Giant Plumbing
How do I reset the float. The pump cycles every
How do I reset the float. The pump cycles every 15 to 20 second. Is that normal.
Bill Haley
    President:
  • Little Giant Master
  • 1,378 Answers
Check your check valve first. If it breaks, the water in the verticle section of pipe will run back into the pit when the pump kicks off and causes short cycles like you describe. Otherwise, what type of float? What brand and model pump?
Posted on Dec 13, 2009
Why isn't the Machine pumping out all the water inbetween cycles?
check the float in the bottom of washer to make sure it is moving up and down all the way and not hanging up causing the water to overfill
Jun 07, 2014 | Dishwashers
I have a 99 haley davidson sportster 1200cc and gas leaks from the carburator at a steady pace, why?
tsomething is sticking the float in the float bowl(bottom of carborator) sometimes you can tap on it lightly and it will unstic also may be a bad gasket always turn the petcock to the off position when noy riding
Apr 24, 2011 | Harley Davidson XL 1200 S Sportster Sport...
The washer floods at the end of the cycle the pump is working this i know because when i manualy lift the mushroom float it pumps out could it be that there is a membrane in the mushroom float that is...
I'm not entirely sure what you mean by "floods at the end of the cycle". Is water leaking from the washer and where from?
The mushroom float isn't a water level sensor to determine when the washer should pump out. It's a second level safety feature to prevent flooding if the washer overfills. The flow meter regulates the water level in the washer.
Your pump is obviously working and there is no blockage in the drain hose, etc as the water pumps out when you lift the mushroom float. It sounds like the pump isn't receiving a signal from the controller to pump out at the end of the wash cycle. Lifting the float bypasses the controller and runs the drain pump.
Please try the following simple test:
1. Switch the programme selector to "Off"
2. Empty a bucket of water into the bottom of the washer
3. Turn the programme selector to any wash cycle
4. Press and hold the Reset button (start/stop) for at least 3 seconds. The washer should drain.
Please try this test and let me know if the washer pumps out. Please can you also be a little more specific about how and where the washer is flooding.
Thanks,
BElectric
Mar 17, 2011 | Bosch 24 in. SGS43C12 Classixx...
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
I have a Bosch Exxcel dishwasher which runs the drain pump constantly even with the door open and despite there being now water in the machine at the cycle wont start. I have checked the warer amtrix and...
I am not sure about this model but most models run a drain cycle for a set period at the start of a wash cycle and then move on to normal filling and cycle of machine provided the various switches are at the low level it will carry on to its set cycle,is the apartment or flood switch ok?
Jun 30, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
When I switch on my dishwasher setting it at normal wash cycle it appears to start as normal then after few seconds goes onto to Eco 45 c wash - the light flashes but nothing happens i.e. no water comes...
you may want to check and clear the pump
you have something slowing your drain
but for giggles make sure your float valve is free to go up and down like it should
all dishwashers attempt to drain first
so you have a conflict between the float position and the pump sensor
Oct 08, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
No power to the main water valve during cycle.
I'm no expert, but I recently had a fill valve replaced. There is a float switch at the bottom of most dishwashers. Its purpose is to cut power to the normally-closed electrically-opened fill valve in the event of an overfill. If the float switch "thinks" there is an over-fill situation, it will cut power to valve, closing it. I would start with replacing the float switch or checking to ensure that it is not stuck in the "up" position due to debris.
Again, I'm no expert.
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
GE 24in. dishwasher GSD5630D00WW
Bill, I see this all the time in GE, that valve under the back strainer is called the piston nut assy. If it's not seating you will have water left in the tub at the end of the cycle. Part #wd24x220, can get it for around 13.95, repairclinic.com. You replace it from the top, it unscrews....Catriver.
Dec 04, 2007 | Dishwashers
Will not shut off at end of the drain cycle
there should be a float behind the fill valve with a magnet in it which operates a reed switch. This switch keeps the pump running as long as the base has water in it or if the float is stuck on the up side (and makes the pump "think" that there's water in the base). Check this float to see if it's stuck and release it so it could tell the pump when to stop draining. Hope this solves your problem.
Jan 31, 2006 | Bosch SHU9916 Dishwasher
Plumbing Logo
421 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
