Question about Samsung CLP-600N Laser Printer
Printer will not power up.
I have a Samsung CLP-600N Laser color printer which will not power up.
There is power to the cord. Could a bad fuser cause this problem or could it be the switch?
  • 526 Answers
If the Printer does not power up, and you tried another outlet and power cord, the problem lies with the power supply in the printer. Unit will need to be taken in for repair.
thanks adi
Posted on Dec 12, 2009
Testimonial: "Thank you for the fast response."
Low Heat error...Cycle Power Samsung ML-2855ND printer
There is a problem with the fuser unit. This unit fuses the toner powder to the paper and if it is not hot enough the toner powder won't bond onto the paper.
Try removing the fuser unit, check the two fuser power spring contacts, and insert it back in the printer. If the error still occurs then you may need a new fuser unit.
You may need to get the printer checked out by a technician.
Mar 19, 2011 | Samsung CLP-600N Laser Printer
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
When I turn on my Samsung CLP-600N laser printer, I just get a clicking noise. When I turn it off, it continues to click for a minute or two and then stops. The lights do not go on.
it sounds like a faulty power supply, when you apply power it charges the capacitors in the psu but as it is faulty is unstable hence the clicking, it continues as the capacitor discharge until all power drains
Apr 20, 2010 | Samsung CLP-600N Laser Printer
Samsung clp 600-N Color is faded and tends to not have enough red in it. Not vibrant color--just kind of blah. Ink cartridges are full and new.
There should be a setting or option to do color callibration, or color correction, if it is just printer and it use ink not toner, you have select cleaning nozel.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Oct 07, 2009 | Samsung CLP-600N Laser Printer
Engine Fuser Low Heat Error on Samsung CLP-600N? What can I do?
i have samsung laserprinter 1610 problom low heat error ple telme anw
ser
Oct 05, 2009 | Samsung CLP-600N Laser Printer
How do i fix Fuser error 3 on clp-650
order a new fuser .... fusers wear out over time
Sep 03, 2009 | Samsung CLP-600N Laser Printer
Samsung CLP-510 Engine Fuser Low Heat error
I would purchase a new colour printer, Brother make some good stuff now and put your toner on fleabay.
1 747results for colour laser printer
Apr 21, 2017 | Samsung CLP-600N Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
Color Printer fan error
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP-600N Laser Printer Logo
689 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
