Question about GE Refrigerators
I have a GE refrigerator side by side that is 2 years old. We noticed last night that food wasn't very cold, so we checked the temperature setting. The setting is at 9 the coldest, yet it doesn't seem to be working. The refrigerator currently doesn't have many items in it, so it isn't like it was trying to chill a full refrigerator. The Model is GSH22JSTA SS. I unplugged the refrigerator for two minutes and plugged back in to see if that would help, but it still doesn't seem to be working. Can you help?
    Scholar:
  • 66 Answers
If the refrigerator is not cooling it could be for a couple reasons.
Either there is an excess of ice buildup between the freezer and the refrigerator or the compressor is bad. If its just and ice buildup all you need to do is remove the ice by either defrosting the refrigerator or using hot water poured down into the air vent inside the machine.
If its not the ice, its probably the compressor in which case you would have to get a professional to come and replace it which is rather costly. In most cases you are better off buying a new machine rather than replacing the compressor. Especially since it is not that old and is already having a major problem. If you decide to buy a new machine I recommend Whirlpool brand appliances.
Posted on Dec 12, 2009
SOURCE:
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Refrigerator temperature shows 60 degrees but waterline is freezing
yes thermastat maybe bad check sencer for temp it maybe bad
Aug 29, 2014 | Refrigerators
Refrigerator is too cold even when adjust the temperature
Too much freon? Or maybe you got the controls mixed up. My refrigerator used to freeze a gallon of milk over-night.
Nov 18, 2012 | GE Adora DSS25KSTSS Stainless Steel Side...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
...The temperature in the frig is now + 40 degrees
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
Feb 24, 2010 | Kenmore 63822 / 63824 Bottom Freezer...
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
