Question about Denon AVR-1508 Receiver
Cracking sound from satellite speakers - Denon AVR-1508 Receiver
  • 757 Answers
Crackling is typical with dirty and/or loose connections in the speaker cable.
If you mounted or otherwise moved your speakers to position them while the speaker cable was connected then it's very possible that some of the threads broke or your connector is loose.
Posted on Dec 12, 2009
How do I fix my sound on the pc? speakers are cracking.
Sounds like the speaker cones are torn. They're made of a paper and break easily on load sound volume. open the speaker to check it.
Hope this helps.
Feb 23, 2015 | HP Computers & Internet
How to I get me satellite speakers to produce sound on the VIZIO Model: S4251 wB4 sound bar?
I thought these sound bar gadgets, were designed to produce the full 5.1 effect, so the satellite speakers would not be required. Never liked the idea of these things, if you have the room, to accomodate a full 5.1 system, then go with that.. If you have space limitations, a sound bar if a good compromise
Jul 20, 2014 | Vizio High Definition Sound Bar
Sound problem
insert a headset into the jack if the sound comes thru it,if sound comes into the jack then check speakers and get the speakers changed.
if both the sound jack and the speakers does not work,check the sound ic on the mother board....
Nov 21, 2013 | Toshiba satellite c660
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
My speakers only the bass when i hook them up i hear the bass but not the sound please help
It sounds like you have subwoofer system that requires satellite speakers for the high frequencies. If you have these satellite speakers, but are getting no sound, either you have connected them incorrectly, or there is a problem with the amplifier that drives the satellites.
Oct 06, 2010 | Altec Lansing 121i Computer Speakers
Speakers sound "cracked", not much volume. Specs state harmon/karmon audio system. Device manager says Realtek..
reinstall the audio driver then restart the computer. you can download the latest audio driver from your computer manufacturer's web site.
Jun 11, 2010 | Toshiba Satellite P25-S5263 Notebook
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
No sound from subwoofer
Yes. The sound you are playing should be 2.1 sound system compatible only then will the woofer work....sodeep
Mar 20, 2009 | HP GM326AA 2.1 Speakers
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
Can i use small satelite speakers with my big front speakers?
Hi, I asume your setting up a home theater with five speakers a center left and right and rear surrounds don't know if you have a subwoofer. The large speakers in the front will work fine if you set the amp to large front speakers the bass will be sent to these. If you have a subwoofer set, the amp to small front speakers and the bass will be directed to it. Also try to get a center channel speaker that sounds somewhat like your large speakers.
Feb 14, 2007 | Yamaha AX-596 Amplifier
Denon AVR-1508 Receiver Logo
190 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
