Question about KitchenAid Dishwashers
A plate broke in the dishwasher and glass fell into the food grinder area. I need to remove the glass. I have one of the KUD10 models of dishwashers.
    Scholar:
  • 66 Answers
In order to remove the glass you will need to lift the top of the grinder off. To do that is a rather complicated procedure however and I would recomend that you have a repair service come to remove the glass. Attempting to do it yourself could damage the inside of the grinder and possibly make your dishwasher not work at all.
Posted on Dec 12, 2009
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
My dishwasher is not cleaning my dishes
Hi btoma313,
Find some info in the Tip below, on what to do if your dishwasher is not cleaning properly.
DISHWASHER NOT CLEANING PROPERLY...
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 19, 2011 | Maytag Dishwasher
Upper arm is not spinning, glasses are dirty after wash
my model which i think is similar is a KUDS011. Had same problem. The food grinder was bad, removing it fixed problem. Fairly easy to get at under bottom propeller. This site has great video's on replacing or disassembly instructions
Feb 24, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Grinder fell. Black "button" inside broke off.
Use just about any 2-part epoxy, clean parts with rubbing alcohol first to remove coffee oil and get a good bond.
Nov 08, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
My kitchenaid fills with water just fine and drains just fine; however when I run it it makes this horrible buzzing/grinding sound. Could it be the food grinder or the pump? How do I clear the grinder to...
You need to remove the lower spray arm, then the water volute that runs up the back needs to get disconnected by removing it from its rear clip (center of tub almost behind upper rack, next twist volute connector clockwise until you can pull the connector and upper supply volute tube apart. Remove connector from top of pump and then remove 5? torx screws to remove top of pump (filter plate) then look inside front section of pump sump area and locate two more torx screws to remove (on right) first sump inlet cover. The screw on the left is for the macerator (grinder assembly) cover. Pull straight up on the cover to expose the chopper assembly. Try not to disturb the chopper screen from it's location as it connects to the pump impellar shaft and is difficult to re-install. Clean any and all debris from the now open areas and re- assemble the pump.
Jun 12, 2010 | KitchenAid KUDR01TJ Dishwasher
Dishes remain dirty, Food particles all over interior of dishwasher. hotpoint dishwasher model HDA2030Z02WW
In the back of the dishwasher at the base there is an indentation. This is where the food particals go when they are washed from the dishes. In this indentation there is a filter and a small wire appendage that is connected to the impeller of the motor. What happens is the dishwasher takes the food off the dishes and it is washed into this indentation area where the wire appendage turns breaking up the food particals to be flushed out during the drain cycle. What it souds like is this filter is clogged to the point no further waste can be flushed out. If you take the bottom tray out and reach into this indentation you will feel the filter. (note) there is a cover over this area that will need to be removed to access this filter. Once the cover is off you can reach into the area and you will feel the filter which should pull up and out. Be very carful when reaching into this area due to broken glass particles that may have accumulated. Once the filter is out clean the area well and replace the filter and you should be good to go
Hope this helped
Dave
Mar 31, 2010 | Dishwashers
Left over soap residue in glasses
you need to flush out the dishwasher, fill a cup with vinager and put it in the dishwasher standing up, then run the dishwasher thru a heavy duty cycle with no dishs. Then cut back on your soap, with new dishwashers and soaps you dont need much at all
Jul 08, 2009 | KitchenAid Food Grinder & Vegetable...
Food on dishes
Dish washers are not good at removing food debris.  They filter the water somewhat but in the main, they recirculate whatever was on the plates when you put them in plus the detergent.  The rinse takes all grease and solubles away.  Scrape your dishes of as much as you can before putting them in.  Use a good detergent in the amount specified.
Nov 26, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore built in dishwasher~2001 model year ,noisey when running.
HI remove the spray tube. remove top cover. look inside that could be a broken piece. this patr can break with pieces of glass going through it. thanks
Oct 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
164 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
