Question about Kirby G4 Bagged Upright Vacuum
Kirby g4 vacuum- need to replace the plastic connection piece between the vacuum bag and the vacuum base...anyone know where and how to do this?
  • Kirby Expert
  • 324 Answers
See if this helps
http://www.goodvac.com/kb_results.asp?ID=12
Good Luck,
Rocky
Posted on Dec 14, 2009
  • 430 Answers
The elbow for the "MINI EMPTOR" will be available only through a professional repair shop or Kirby dealer. It will usually be fastened internally with a cable tie and sometimes one underneath the cuff of the bag. remove your paper bag and follow the flex fill hose to the bottom to see what you need to do. Roll the outer cuff for better view as well
Posted on Dec 13, 2009
Fan blade cracked
It needs replaced before it breaks and pieces get into the motor.
Replacement instructions can be found at http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html.
Jan 03, 2011 | Kirby G4 Bagged Upright Vacuum
I have a G4 and the plastic at bottom of bag is cracked
Hi There,
Well sort of. For the G4, the bottom boot is sold with the internal fill tube that inside of the outer bag, where the paper bag connects. These two parts are sold complete as an assembly already put together. You'll just need to take off the strap at the bottom of the boot that holds the outer bag onto the boot. This strap is sometimes difficult, and sometimes it's easier to just purchase a new strap and install it.
Here are direct links to the parts that you'll need on our website:
Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S
And here's the bag strap that you may just want to purchase so you can just cut the old one off:
Kirby Vacuum Bag Clamp. Kirby Part # 196599S
If you have any questions about how to change this part out, please feel free to open a new repair, or just use the comment field here on Fixya. If you found this repair helpful, please follow the Fixya way and leave feedback for the repair. This is really appreciated when someone answers your repair questions, and is what keeps repair professionals continue to post free answers rather then just the paid ones. Thanks again,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby g4 tech drive, when plugged won't come on ,is it the motor or something else ?
Does anyone know if there is a reset button on the Kirby G4? And if there is where it is?
Jan 03, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 causes black streaking when shampooing carpet
Replace the belt it is probably worn. You can get a replacement here:
Kirby G4 Belt
Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G3
Beginning with the G series, G3 and G4 had round openings for the dirt intake. Prior models had oval so they will not fit, so find G3 or G4 bags and you will be set
Sep 09, 2009 | Kirby Generation 3 Bagged Upright Vacuum
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Sep 30, 2008 | Kirby G4 Bagged Upright Vacuum
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Rainbow e-series not working
Pop off the clear plastic side pieces and the 4 screws are located underneath. I suggest checking the carbon brushes and armature, as these are the parts of the e series that are most generally in need of replacement.
Marci
Oct 27, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
115 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
