Question about Mitsubishi HC3000U Multimedia Projector
Fine sync and tracking menu not available after I changed the bulb. Picture is a little fuzzy.
    President:
  • 1,447 Answers
Adjust power label or check bulb amp & volt.
Posted on Dec 13, 2009
The tv gets really fuzzy and changes color after watching it, but i think it has something to do with the wire ports because if i hit menu while its all fuzzy, and when the menu comes up it looks normal,...
check cable connections:
1. cable from wall to tv or to pvr. properly connected?
2. yellow,red and white in correct ports?
3. if HD, use green, blue and red to respective ports.
4. is remote properly sync to tv?
5. if no 3 above, get HDMI cable and connect to pvr.
Aug 12, 2013 | Westinghouse LTV-32w3 HD Television
How do I get the picture?
The TV is usually set to Channel 3 or Channel 4. You may have a switch on the back of the VHS recorder near which is marked Ch3 Ch4.
Once you correct this, try the following procedure.
Some VHS have a tracking button that allows the user to tune to the best signal. The tracking can also be done from the remote controller.
Usually that tracking function is used as follows.
While movie is playing on the VHS unit and signal gets fuzzy, press the channel key repeatedly (for example >> to increase the channel number). f after awhile pressing the same channel change button does not find a better picture, you should press the other channel change button (to decrease the channel number <<) to see if the picture improves.
If that does not work, IT DOES NOT MEAN that you tv/vcr combo unit is defective. It could just be the movie. The tape is magnetic and it might have been accidentally demagnetized.
If picture is better with another movie/tape, your unit is definitely OK.
May 20, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
When viewing photos it?s striped/fuzzy
Try pressing the up/down on the multiselector. Does that change the view? If so, you've just discovered how to cycle through different views of the image.
If that doesn't do anything, then do the menu and info screens come up correctly, or are they also striped or fuzzy? If so, then the camera may need servicing.
Jan 12, 2010 | Nikon D3000 Digital Camera
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Fuzzy picture and in a different language
click on "menu".
then move to the "hand" while clicking on lightview
then clivk select/auto
it should automatically select the third from above
then move to the top while clicking on lightview
and now change the language with the "sun" buttons
Dec 17, 2007 | LG Flatron L1715S 17" LCD Monitor
Mitsubishi HC3000U Multimedia Projector Logo
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
