Question about Kenmore Kitchen Ranges
My kenmore range is displaying an error code EO -F2- and i have looked at the manual and it tells me to unhook the keytail connector. But, it doesnt tell me where or what the keytail connector is. all the wiring looks ok to me.
  • clinton_case Dec 12, 2009
    theres a couple of ribbon connectors going to the display but they all look alright. i unplugged them from the board and they seem to be in good condition. no broken wires or anything. still getting the error code.
    theres a couple of connections to the display and they all look ok. i unplugged them and there doesnt appear to be any damage.
  • Kenmore Master
  • 19,396 Answers
Hi.
E0-F2 Means that the keypad is faulty or disconnected.
Before doing anything, trip the circuit breaker and disconnect power for a couple of minutes.
The keytail connector is the ribbon cable that connects the control pad to the electronic control.
Enter model number here to get parts and schematics: Parts & Accessories
Posted on Dec 12, 2009
Kenmore electric stove model 95012102 displays EO-F2 the cooktop works.
that code is a bad touchpad.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1cHA0Nn50
Oct 30, 2011 | Kitchen Ranges
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
Electric Kenmore range has the code E1 F2 and beeps. What is wrong
Hi
Thanks for using FixYa. Error F2-E1 in your Kenmore range indicates shorted keypad. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 06, 2010 | Kenmore 72002 / 72004 Kitchen Range
While using the oven, a code EO-F2- appeared and would no longe heat.
Sep 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Kenmore gas range beeps and displays code E1-F2
Hello, E1 error code relates to the EOC (electronic oven control) Failure. You should turn the breaker off for 30 seconds and then switch back on. This might clear the error code. If this does not clear up with the reset I have just mentioned you are going to have to replace the EOC, This can be located in the control panel by removing the screws from the back. If you have any other questions please feel free to comment again. Good Luck! Mike
Sep 10, 2009 | Kenmore Kitchen Ranges
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Error message EO F2
that fault refers to a shorted key panel, recommended repair is to replace replace Electronic Range Control/Clock (erc)
Feb 24, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Kitchen Ranges Logo
47 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
