Question about Pentax Optio M20 Digital Camera
Pentax Optio M20: won't work.
Hi. I have a Pentax Optio M20 Digital Camera. When I hit the on/off button, the camera turns on, the lens zooms out for a second and then back in, then it shows the "Pentax Optio M" load screen, then it shows "Auto Picture" in the center and a green dot in the bottom left with the words "EV Compensation" next to the dot. While it's showing this last screen, it beeps 3 times right before the lens zooms out again then back in just before the camera turns off. I have changed the batteries multiple times. So it's not the batteries. I connected it to the computer and then hit the on/off button. It beeps twice before the red LED light in the front of the camera lights up while the removable disk window pops up on my computer, showing 2 folders ("DCIM", and "FRAME"). I click on these folders and there's nothing in them. I hit the "on/off" button on the camera again and it turns off while the removable disk window on my computer goes away. None of the other buttons on the camera seemed to do anything whether connected to the computer or not, during every phase of it's on status. What can be done to resolve this? Thank you.
  • 2 more comments
  • Anonymous Feb 10, 2008
  • Anonymous Feb 18, 2008
    i can scroll through the pictures, and mess around with them, but when the camera is in picture taking mode, it turns off within 3 seconds and i can't change anything
  • bablu21 Mar 25, 2008
  • Giffordusher Apr 17, 2008
    When I turn my camera on, it makes a beeping tone and the lens extends and the screen turns on, all normal; however, once the lens is fully extended, the camera then makes a buzzing sound which is not normal. It then goes into shutdown mode, making a normal beeping sound as the lens detracts and the screen shuts off, and a second buzz occurs, which is not a part of the normal shutdown sequence. The whole process takes about 5 seconds, from the time I push the on button, until the camera has returned to the off setting.
    I tried the suggestion of turning the camera on while holding the "play" button, and this worked to turn the camera on in display only mode, so I could see pictures, but it will not switch to camera mode. I held the "play" button down for up to 30 seconds, and tried to repeated push the "play" button, but the camera remained in display only mode.
Ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Posted on Apr 12, 2008
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Posted on Feb 20, 2008
2 Suggested Answers
svenby
  • 66 Answers
SOURCE: camera problem
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Posted on May 30, 2008
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Optio M20 Stuck on Zoom in and out!
you have a timing problem,the gears for your housing is out of calibration with your focus lens inside of the housing. you must take the camera apart to correct the problem.there is a flywheel type of ajustment in the top of the camera that can be turned to bring the camera back to its reset position. it is bad to keep turning on the camera as this may danage the gear that is out of time.
Sep 12, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Camera problem
Feb 10, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20
Jan 01, 2008 | Pentax Optio S Digital Camera
Optio M20 Beeping
You certainly need to use high capacity Ni-Mah or lithium batteries. Using alkaline would have caused overheating and may therefore have damaged the board. You are right to ask is a repair worth it? Almost certainly the answer is no even if possible. There are usually no spare parts available. Go back to tech support and this time simply report the bare facts -'It wont stay on'. Say nothing about the battery situation. Depending on the age of the device you may be offered a reasonable swap out price.
Jul 14, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio M20 Digital Camera Logo
385 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
