Question about ViewSonic G790 19" CRT Monitor
Color my color went crazy and so i was wondering how do i get the color numers back were they should be right now they are at 84 red 85 green 70 blue. HELP!
  • Anonymous May 07, 2008
    how do i put adjust the red tone back into my monitor
  • 23 Answers
Your monitor CRT gone bad.
Posted on Jan 21, 2008
Don't know radio connector color code
This should help.
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
Sep 20, 2011 | 1987 Plymouth Voyager
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1996 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1996
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: Retain Keyless entry with secondary Harness Listed Below
Additional Accessories:
Metra Brand Dash Kit: 89-30-7891 - 99-7891 - 99-7898
Metra Brand Wiring Harness: 70-1720 W/Keyless Entry # 70-1720T
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Ignition 2: Yellow - Ignition Switch Harness
Accessory: White/Black - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Blue/Black - (-) Driver's Kick Panel
Parking Lights: Red/Black - (+) Driver's Kick Panel
Head Lamp: Red/White (L) Red/Blue (R) - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Above Fuse Panel
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Orange - (-) Module Behind Radio
Horn: Grey - Steering Column or GREEN connector behind radio
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : Blue/White - Driver's Side Dash Footwell, Grey connector.
NOTES: PPM - 4000PPM
ROSTRA Control Arm # 250-3421/250-1483
ROSTRA Throttle Adapter #250-4249
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
1984
1985
1986
1987
Constant 12V+: White/Blue
Ground: Black
Dimmer: n/a
Front Speakers:
Left Front (+) Blue/Green
Rear Speakers:
NOTES: - none -
Metra Brand Dash Kit: n/a
1984, 1985:70-1388
1986, 1987:70-1720
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
I need help with the color there is no red or green went thru the manual and the sample colors are ok, went back to regular program and colors are terrible,
check you cables like a VGA monitor you have three colors Red Green Blue on the cable and if one is broken then the color will not come in correct. on your device that feeds video to the tv try some different cables and inputs it might be a bad cable
Jan 02, 2011 | Philips 42PFL3704D LCD TV
What colors go to what colors of the stock wiering
If your car does not have an amp. use this wiring harness
Metra Electronics Corp. 70-5600
FORD Ranger/Explorer 1995-Up - Into Car. I f you car has amp. you need this one Metra Electronics Corp. 70-5603
Factory amplifier integration harness. I recomend you to by one of this wiring harnes is easy for you.
1998 Lincoln Navigator Car Stereo Wiring Diagram
Radio Battery Constant 12v+ Wire: White/Violet
Radio Accessory Switched 12v+ Wire: Black/Pink
Radio Ground Wire: Black/Green
Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow/Red
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Blue/Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Violet/White
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2010 | Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Color not right
HI
you have defective RGB Circuit The Red, Green, Blue, You have shorted Green Circuit in Crt circuit this needs to diagnose to locate the shorted parts...
Thanks!
Apr 12, 2009 | Zenith B27A11Z 27" TV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
ViewSonic G790 19" CRT Monitor Logo
69 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
