Question about Akai LCT3701AD 37 in. LCD Television
TV won't come on
This problem began a while ago, but the TV would eventually come on after several tries. Now it doesn't do anything. The TV is 3 years old. Any idea how much a repair would run?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Asper the heading of the issue it is Akai LCT3701AD 37 inch LCD Television. If itis the same model then this issue is happening due to the power board or theX-sus board. However, this usually happens due to the Power board. You'll needto disassemble the TV to be sure where exactly the issue is. If it’s the powerboard, then you'll be able to see swollen/bulged capacitors on the board.
However, if it’s an X-sus (logicboard) then you'll need to check the connector cables connected to it and alsothe components connected on the board. You'll need a multimeter to check thesethings out. If both the above parts are required to be replaced, then itwill cost from $150-300 which you can buy online from the link---
Akai LCT3701ADLCD TV parts
Please do accept the solution ifthe issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Dec 12, 2009
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
I have 2001 mercury courage replace alternator 2wks ago ran great. Now today will not start. Tried to start and it would click when I turned key now won't do anything doesn't have any power....
Could quite possibly be you have a bad starter. I would have it tested. Could also be a bad battery. If, when jumping it, you used too high of a voltage, could have shorted out a wire somewhere
Oct 27, 2012 | Cars & Trucks
2003 mini cooper AC compressor doesn't run
indicates a low gas problem
have it properly diagnosed by an ac specialist shop
Oct 30, 2017 | Mini Cooper Cars & Trucks
The compressor will last a lot longer. Your problem is a very slow Freon/refrigerant leak from when the compressor was replaced. If you wish, you could put in a canister or 2 of refrigerant from an auto parts store, as a kit with the re-fill line, to make it work for a while. But eventually you're going to want someone to find that leak and repair it. Best of luck my friend.
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
The TV won't come on. This began a while ago, but the TV would eventually come on. Now it doesn't do anything. The TV is 3 years old. Any idea how much a repair would run?
Hi
please inspet the circuit board of your Tv...and chek whether any wire is broken which needs to get soldering .Resoldering the circuit will mend your problem or please check whether any fuse is needed to be repalced or not.
Thanks for contacting fixya.com
Dec 11, 2009 | Akai LCT3201TD 32 in. LCD Television
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My toshiba flat screen tv 20AF41 does not turn on. I can hear a click every few seconds until I unplug it but that's all. The problem began a couple of months ago, it had happened several times (using the...
The problem, whatever it is, has resulted in a short circuit condition which has activated the protection system.
The set will need servicing in all likelyhood. Do a hard reset to see if that will restore operations; if not, you will need service. A hard reset is easiest to achieve by unplugging the power cord for 4 hours or more. Then try again.
If the hard reset does not help it will likely cost around $150 plus the house call. But, a tech will need hands-on measurements to isolate the problem to the exact failing components.
Oct 05, 2009 | Televison & Video
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
I bought a Toshiba 42'' plasma TV exactly 1 year ago. The model, as per the hand book, is 42PD6600 A. About 8 weeks ago I began experiencing some problems to turn on the TV, i.e. the red light (stand...
maybe your ac cable has a lost contact thats why when you wiggle it it will turn on. just replace your power cable first before you are going to troubleshoot the other problem.
regards,
janex
Apr 22, 2008 | Televison & Video
Akai LCT3701AD 37 in. LCD Television Logo
77 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
