Question about Sony ICF-C318 AM/FM Clock Radio ( White )
How can I adjust the time? The clock is quicker
How can I adjust the time? The clock is five minutes' quicker. What is the function of "clock, - +"?
  • 63 Answers
Yes you can adjust the time. usally you hold down the mode button and then press the seconds button, do that until you get the right time.
Posted on Dec 12, 2009
SOURCE:
How to set clock in radio on a 2014 Jeep Patriot
Clock Setting Procedure 1. Press and hold the TIME button until the hours blink. 2. Adjust the hours by turning the right side TUNE/ SCROLL control knob. 3. After adjusting the hours, press the right side TUNE/ SCROLL control knob to set the minutes. The minutes will begin to blink. 4. Adjust the minutes using the right side TUNE/ SCROLL control knob. Press the TUNE/SCROLL control knob to save the time change. 5. To exit, press any button/knob or wait five seconds http://www.chryslercommercialvehicles.com/jeep/download/pdf/manuals/2014-Patriot-OM-1st.pdf page 240
Mar 12, 2015 | 2014 Jeep Patriot
Set clock
Turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
May 02, 2014 | 2008 Harley Davidson FXDWG Dyna Wide Glide
Set clock 08 fxdwg
May 02, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
How to reset clock on 2010 softail deluxe?
Apr 26, 2014 | Harley Davidson FLSTN- FLSTNI Softail...
Need to know how to set time on ISTA SET 40009
Instructions
    • 1 Press and hold the "Alarm Set" button for five to seven seconds if you have an Insta-Set 40001, 44100 or 44200 model; the year will begin to blink when the clock is ready for adjustment. If you have an Insta-Set 40009 or 40018, hold the "DST" button for five to seven seconds (until the hour begins to blink).
    • 2 Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
    • 3 Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
    • 4 Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Read more: How to Change the Time on an Equity Insta-Set Clock ' eHow.com http://www.ehow.com/how_5657092_change-time-equity-insta_set-clock.html#ixzz1d1qIibS4
Nov 07, 2011 | Equity Time USA Insta-Set 40009 clock
This clock is an automatic set clock and it is 15 minutes ahead in each timezone and is not able to be reset by us
Press and hold the "Alarm Set" button for five to seven seconds and the year will begin to blink when the clock is ready for adjustment. .
Press alarm 2 to change from Celsius to Fahrenheit.
Press alarm 1 to change from 24 hr time to 12 hr time.
Aug 08, 2011 | Equity Time USA Insta-Set 44200 Clock...
How do you set the clock on a 2008 harley dyna super glide on the speedometer?
FOR 2009 turn the ignition switch to ACC or IGNITION, press the function switch until time (hour and minutes) is displayed. Press and hold the function switch for five seconds or until 12HR begins to blink in the speedometer display window. Then release the button. THEN press and release the function switch once to advance to a blinking 24HR or military style time display. Then each time you press and release the switch, the display will change from 12HR and 24HR. When the desired time is displayed, press and hold the function switch for five seconds and the display will switch to the time display with the hours blinking. There is NO AM/PM setting. Press and release the function switch repeatedly to advance the hours to the hour you want. It will advance by one hour with each press of the switch. WHEN the desired hour is displayed press and hold the function switch for five seconds and the minutes display will appear and blink. THEN press the function switch repeatedly until the desired minutes display is attained (the minutes value will change by one minute for each switch depression) and then press and hold the function switch for five seconds and the minutes display will stop blinking which indicates that the time has been set. Turn the ignition switch off and the time you set has been saved and will change as time passes.
Jul 30, 2011 | Harley Davidson FXD Dyna Super Glide...
Setting clock on 2006 Pt crusier
Clock Setting Procedure (digital clock page 242 of your owners manual)
1. Press and hold the time button until the hours blink.
2. Adjust the hours by turning the right side Tune/
Audio control.
3. After the hours are adjusted, press the right side
Tune/Audio control to set the minutes. The minutes will
begin to blink.
4. Adjust the minutes using the right side Tune/Audio
control.
5. To exit, press any button/knob or wait 5 seconds.
SETTING THE ANALOG CLOCK (page 238 of your owners manual)
To set the analog clock at the top center of the instrument
panel, press and hold the button until the setting is
correct. The clock will adjust slowly at first and then
quicker the longer the button is held.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 26, 2011 | Chrysler PT Cruiser Cars & Trucks
How do I set clock on a 2006 Pt Cruiser. I hold the time button down and can set hour but can't set minutes.
Audio control.
begin to blink.
control.
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Sony ICF-C318 AM/FM Clock Radio ( White ) Logo
436 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
