Question about Kenmore KMX10T Hand Mixer
Lost one of the beators - Kenmore KMX10T Hand Mixer
  • 3 Answers
That model was discontinued back in 2007. I;d be happy to buy it from you- I'm a student in Ottawa, Canada. email me jasondvmgroove@gmail.com if you're interested. thanks.
-Jason
Posted on Apr 05, 2011
I need to get to the speed control to find a broken cord. I can get the appliance apart but cant get the speed control out.
A broken part ? or is only the potentiometer of the speed control thats damaged, but a wire that is broken ? without any force is hard to believe the spring element internally that moves along the carbon track of the potentiometer inbetween the speed control should have lost the contact pressure or only dirthy ?. where the resist for rpm mixing is lost. maybe marketing technical made to order it as a one-part assembly try contactspray in the potentiometer.
Aug 11, 2016 | Sunbeam Food Mixers
While kneading bread my mixer suddenly starting hanging up at the back side. It makes the full circle but when it gets to the back it stops and "hums" and then sometimes will go on but most of the time...
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
Feb 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Mixer was shipped on it's side, and arrived leaking oil, is it o.k. to operate?
Yes your machine is safe to use as long as to much was not lost. the manufacturer (whirlpool) always puts more grease inside the transmission than needed. As long as you aren't getting continuous leaking this will be fine to operate. you can buy more grease if a lot was in fact lost. this can be bought at an auto supply shop. it is a thicker bearing grease.hope this helps
Thanks
Oct 08, 2009 | KitchenAid Food Mixers
Older Kitchenaid mixer has lost the two top speeds
Hi Leslie. www.mendingshed.com has a Kitchenaid Repair Manual available for a free download. If you're going to attempt a repair yourself, this manual will come in handy. You haven't said what model of mixer you have, so I'm only able to guess that this manual will cover your needs.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 21, 2009 | KitchenAid K45SS Classic Stand Mixer
Have lost some oil out of it in moving, what oil
Hi. The oil you see used to be mixed into the grease base. It's time to change the grease in your mixer. Remove the silver band, Remove the top cover. Remove the transmission cover. Clean out the transmission, remove all grease and oil. Replace with Chevron FM ALC EP-2 grease. This grease is an edible food grade..
Remove the planetary gear, clean and re-grease. If this solution has assisted you, please rate it. ricardok45
Mar 15, 2009 | KitchenAid Food Mixers
Lost beaters
Either call or contact the company by phone and ask for assistance in replacement parts.
Jan 05, 2009 | Betty Crocker 340 Watts BCF1250 Stand...
Lost beaters
Toastmaster factory parts
http://abtecparts.com/toastmaster.htm
Jerry G.
May 23, 2008 | Food Mixers
Kenmore KMX10T Hand Mixer Logo
61 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
Darial Jr Lasaria
Darial Jr Lasaria
john h
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
