Question about Gigabyte GA-8VM800PMD-775 Motherboard
Vga card is dead so the nothing showing on the screen
I would like to install a new vga card cause the onboard card is not workin how to disable onboard card
  • 1,684 Answers
On motherboards with built in video cards when you plug in a new card the on board card is automatically disabled. Just plug the card in and connect your monitor.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 12, 2009
VisionTek Radeon HD 5450 VHDCI doesn't seem to recognize monitors?
Try one monitor at a time, if you get nothing, reseat the card, if you get nothing try another port like display port or hdmi. If you get nothing take the card out and try the onboard graphics. IF you get something with the onboard, replace the card.
Apr 03, 2017 | VisionTek Computers & Internet
My gf9400 gt 1gb shows blue screen, until booting it works but while loading win 7 it crash dump blue screen appears every time???? but after plug out graphic card and plug in onboard vga works fine what...
Hello bsod often means you have a driver problem, or a graphic card problem.
The graphic card could have a defect, this can cause the blue screen.
Try also to check the device manager, for any other drivers missing.
Try first to download and install the newest driver from nvidia:
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.07-whql-driver.html
This is the 64 bit driver.
The 32 bit is here:
http://www.nvidia.com/object/win8-win7-winvista-32bit-314.07-whql-driver.html
If i am wrong by my selection, choose another here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Or use Automatically find drivers for my NVIDIA products, by installing a small bit of software.
If the driver update does not help, the graphic card must be renewed.
My advice is to uninstall ALL the old nvidia software, before you install the new.
Are the onboard graphic nvidia ???
This can sometimes create a conflict, when the graphic card brand are the same.
Try to disable the onboard graphic, in the device manager.
Good luck
Mar 05, 2013 | InnoVISION Multimedia Technologies Inno3D...
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
EV3A GT520 video card installation makes my screen go blank. My gateway computer has an integrated chip for video, and does not even recognize the new card but its plugged in, fan working, etc.
some bios settings disables the add on video cards. to enable them go to bios setting by pressing DEL or F12 while power on your system. (u will see that a message appears "press ----- Key to enter bios settings). after entering bios setting u will see onboard VGA enable/disable. u have to disable onboard VGA in order to get the display thruogh VGA card.
Sep 21, 2011 | Nvidia GeForce GT 520 1 GB DDR3 Video Card...
How to disable onboard graphics in D845epi so as to install Grpahics card? My onboard VGA is demage (not work)
When you power up the computer press F1 or F2 or "del" key or ALT +F2 then you can see bios screen.
Then go to advanced menu and disable onboard vga .
Then save settings of bios and exit.
Then your onboard vga is disable so you can install vga card into it.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 14, 2010 | Intel Desktop Board D845EPI Motherboard
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
Want to disable onboard graphics to install and use pci vga card
You should be able to turn it off by booting the pc up into the Bios and changing your video settings to AGP.
May 17, 2008 | EliteGroup P4VMM2 Motherboard
How do I disable vga on ga-8vm800m?
During boot press DEL to get into standard BIOS settings, while in standard BIOS hold CTL key and press F1 this will alow hidden features to show in BIOS. Enter into Integrated Peripherals and you should now see a entry called INIT DISPLAY FIRST and you should be able to select between PCI Onboard and AGP (Depending on what you have installed). I have the same motherboard and had also upgraded to the 6200 which works great after finding the hidden BIOS features.
Hope this does the trick for you!
Jan 29, 2008 | Gigabyte GA-8VM800M Motherboard
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Apr 28, 2007 | XFX GeForce FX 6800 (256 MB) Graphic Card
Gigabyte GA-8VM800PMD-775 Motherboard Logo
124 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
