Question about Frigidaire FEF336BC Electric Kitchen Range
Clean Oven Door Glass
How does one access the oven door to clean the glass. There are 4-5 screws in the door but I am not sure if that provides access to the glass.
  • quillerm Jan 27, 2008
    Do you have information on how to replace the oven door glass? I can use that to remove/disassemble the door and try to clean it.
  • kcthearcher May 25, 2009
    Replying to Tech 17. Yes, still want to clean oven door.
Take the door off.
Lay it on a flat surface-front down.
Remove six screws- 2 holding handle and 4 a bottom.
Carefully remove top part door assembly from front cover.
Clean glass.
Reverse the process to reassemble.
Posted on Mar 18, 2008
    President:
  • 1,314 Answers
Its really not worth the effort there are acout 4 different pieces of glass in there most of the times the stains are backed on and cant be gotten off the two inner pieces are about 100 usd apiece and you need to remove the door to take it appart if you deciede you still want to ill instruct just reply to this thread
Posted on Jan 20, 2008
2 Suggested Answers
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Aeg oven door
Most of those glass panels are a sealed pack and are not able to be separated. Usually there are screws around the edge of the door that holds the door together and if you were going to replace the glass you would take those out to separate the inside panel of the door from the outside of the door and that would give you access to the glass area. You could try that but I do not know for sure if you will actually be able to separate the glass to clean it.
Dec 03, 2013 | Ovens
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have cleaned my oven in a house I have just moved into. but I cannot get to the double glass in the door, how do I clean in the middle of both peaces of glass. There are no visable screws or clips like...
this is all i could find out...
How to clean between the glass panes on an oven door:
  1. Remove the access panel or drawer below the oven door.
  2. Attach a moistened glass cleaning wipe to a piece of coat hanger wire.
  3. Slide the wire and cleaning wipe up through the slots in the bottom of the oven door.
More items...
How to Clean Inside the Glass on an Oven Door ' Today's Homeowner..
or go to this link..
how to clean double glass oven door Google Search
Oct 27, 2017 | Caple C203 Electric Single Oven
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Using a long stick/tool, attach a cloth to the end. Remove the drawer and look up at the oven door. There are 2- 3 openings that are big enough for you to reach the mess. Make sure that whatever you are using to clean the glass will not stay stuck inside, so make sure its attached securely. I used the end of back scratcher with a thin cloth attached to it. After a few attempts, I was able to completely remove the stain that was caught between the two panels. AND... I didn't need to remove any screws or dismantle the door. This could void your warranty.
Jul 22, 2008 | Maytag PER5510 Performa Electric Kitchen...
Two screws
May 24, 2008 | Frigidaire FES367 Electric Kitchen Range
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Frigidaire FEF336BC Electric Kitchen Range Logo
576 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
