Question about Dell OptiPlex GX270 PC Desktop
Computer will not load. I push the power button and it just runs.
  • 3,940 Answers
Here are some things to check
  1. Power LED (It should be solid green) if flashing or solid Amber, then a power supply or motherboard problem.
  2. On the back, near the PS2 Ports, are 4 diagnostic LEDs marked ABCD. When running normally they are all green. During boot they flash on and off during each sequence of the POST, if they stop at t code AAGG for example is bad RAM
  3. If the Power and Diag LEDs are normal, then reseat the video card if an AGP card is installed or remove it an try the integrated video.
Posted on Dec 12, 2009
Asus ux 31 user profile
hi, try this: turn pc off- push power button and push f8 many times with 1 second inbetween every f8 push
you will see a black screen with white print
use arrow keys to highlight repair computer
let it finish repair
after it starts user profile, run a disk check= google it lots of info
check antivirus and run scan- don't use Norton avast is good and free- also use malawarebytes to scan- you should be good now
happy trails.....
Mar 30, 2014 | Asus Systems Asus ZenBook UX31E-DH53...
Computer won't power on right away
Wll it could be your pci controller is damaged.. (In thic case the only solution is to buy a new board)
Or you bios might need flashing..
Unplug your system
Open up the system,
put back in your network card
remove the battery on the main board
hit the power button 7 times
replace the battery
plug it back in and try to boot now
When it boots, you need to enter the setup and load your default settings then save and exit..
Jan 24, 2008 | Intel D915PCY Motherboard
ML350 G4 will not boot. System was running but became unresponsive. Powered down using power button. Now no response to pushing power button. No Leds lit anywhere. Fans running on power supplies.
Try pulling the hot swap Power supplies, push the power button hole the supplies are out to discharge power, then put them back in again and try the power button again.
Oct 28, 2013 | HP ProLiant ML350 G4 Server
When you push the power button, the button turns green but the computer doesnt start up. The lights are on but there is nobody home, there is no sound indicating that the computer is starting up.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 18, 2011 | Acer Aspire 9300 Notebook
My computer will not start up. When I push the power button it will go to a black screen. You can hear the computer running but nothing is going on at the screen. What can I do?
you just need to load the BIOS to its defaults, to do this you need to open the CPU case, unscrew the two screws on the left side of your cabinet, on the motherboard you can see a small button sized battery, remove it and after one minute replace it into its position.
close the cabinet and start the computer it'll work fine....
Sep 06, 2010 | Computers & Internet
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Intel d945gnt bios won't load when power up...
there might be problems with the ram you are using.. try your friend's ram in your computer. if it works without the problem you specified , go for replacing your ram. if the problem persists contact us back. thanks for using fix Ya!
May 26, 2009 | Intel D945GNT Motherboard
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Problem in sofware
switching to recovery mode is easy. simply connect the device to your computer, then push over the hold button so the orange is showing. next push and hold the record button and at the same time push and hold the power button. after a few seconds it should go to recovery mode. best of luck : )
Feb 14, 2008 | SanDisk Sansa e260 MP3 Player
Dell OptiPlex GX270 PC Desktop Logo
211 people viewed this question
Alun Cox
