Question about Remote Start System
Change VIPER Responder One runtime
I have a VIPER Responder One remote car start and would like to change the run time from the default 12 minutes to 24 minutes. I don't have the installation manual and the owner guide doesn't tell how.
    Problem Solver:
  • 18 Answers
Actually the first solution may or may not be true. If whomever installed the remote starter "locked" the programming with a bitwriter, then you will need to take it back to someone with a bitwriter to unlock and change the setting. If it was not locked then you can change run times for that model yourself. You have choices of 12, 24 or 60 minutes. 12 is the factory setting (with a bitwriter you can choose in one minute increments). If your system is unlocked this is how you can change the runtime setting. It's a bit of a pain so you might want to write it down. There should be a small programming button attached to wires coming from the "brain". First, locate that button. 1. Turn ignition key on then back off. 2. Quickly push and HOLD the programming button. If the horn was hooked up to the remote start system, it should honk once. (If it wasn't you'll have to look for a small led status light on the brain that should flash once) To change runtime, keep holding the button down till the horn honks twice (or the led flashes twice). 3. Release button after horn honks twice (or led flashes twice.) You are now in menu two where runtime is set. 4. Within 10 seconds, press and release the programming button two times. Now push and HOLD the programming button. You are now on feature two of menu two (runtime options). While still holding the programming button in, press the remote start button on the fob the number of times that corresponds with the run time you want. once = 12 minutes, twice = 24 minutes and three times equals 60 minutes. After selection has been made release programming button. The programming sequence will be cancelled if any of the following occur: Ignition is turned on or programming button is pressed too many times or more than 25 seconds elapses between steps. Like I said, it is a pain to do manually and there is a possibility you could mess up other settings if you get it wrong. But this is what the install manual states if you want to give it a go. Good luck!
Posted on Feb 07, 2011
  • 4 Answers
You MUST take it to your local professtional installers shop to have that done! It only takes a minute or two.
Posted on Dec 17, 2010
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
How do you reprogram start duration for a longer time
You do realize that there are multiple remote starter manufacturers and, that these multiple manufacturers have different programming methods. However, the 12 minute run time is a default run time for Directed Electronics (Viper, Python, Clifford, Avital, etc) but, that does not mean that it is a DEI product. If it is a DEI product and you wish to change your runtime to 20 minutes, it can only be done with a BITWRITER. The installer should have this. The runtime settings that are optional without the bitwriter are 12, 24 and, 60 minutes for the more expensive units.
Jan 14, 2013 | Vehicle Parts & Accessories
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
When I try to use my automatic start on my viper sst my car wont start up.
The Remote start is hooked up wrong. They have the power for the starter connected to the wrong wire. Its not reading that the car has started and when you put the key in it recognizes that its running. Take in it to who ever installed it and have them change those wires around.
Nov 09, 2011 | 5900 SST 2-Way Security System / Remote...
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
I had a viper 5701 responder LE 2 way system installed on my 2006 dodge Dakota, everything works fine but my headlights and parks lights stay on constant while in remote operation and my park lights do...
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Dec 17, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote Start System  Logo
2,157 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
