Question about Brother Disney PE-400D Computerized Sewing Machine
Brother PE 400 D threading bobbin problems
First my machine started saying "check if upper or lower thread is broke" even though it wasn't and we took the bobbin section apart and now it will not thread the bobbin through
Bobbin thread is coming up side while designing
Posted on Mar 27, 2011
  • 397 Answers
Im going to help you as much as i can,,,,try using a bobbin that is already threaded and make sure bobbin is in bobbin case correctly, make sure machine is threaded to instructions in book,,,if this is all done exactly u should not have a problem unless something is jammed
Posted on Jan 20, 2008
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
Brother pe770 bobbin thread is showing on top of fabric.
First check threading. If it is done properly, then it's probably because it is dirty between the lower tension blade and the bobbin case body. Remove this blade, clean, reassemble and it shoud work.
Dec 26, 2011 | Brother PE770 Computerized Sewing Machine
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
Lower thread keeps jamming even though bobbin case is clean and tension on thread has been adjusted.
Here are some things to try.
* Re-thread your machine
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
Also, before you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope one of these solutions help.
Sep 15, 2009 | Brother LS-2125 Mechanical Sewing Machine
Tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Feb 27, 2009 | Brother ES2000 Computerized Sewing Machine
My brother PE-400 sewing quit sewing
i had the same problem and realized i was using the wrong kind of bobbin. there are specific ones for an embroidery machine and specific ones for a reg. sewing machine. hope this helps
Jan 31, 2009 | Brother PE-150V Computerized Sewing...
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
Jan 02, 2009 | Brother Disney PE-400D Computerized Sewing...
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Brother Disney PE-400D Computerized Sewing Machine Logo
185 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
