Question about Whirlpool Refrigerators
My referigerator is running coolabout 45 degrees.freezer/wmer sometimes. thefreezer is not gttig real cold. hope you can give a idea of what may be wrong
    Scholar:
  • 66 Answers
You may have a sealing issue with the freezer door. If the rubber gasket around the edge of the freezer door is not sealing properly it will cause the freezer to be warmer. You may not easily notice the seal problem so check it all around the four edges of the freezer. hope this helps :)
Posted on Dec 12, 2009
Fridge started working again after I cleaned the grill, then freezer stoppped, unplugged and waited now freezer is good but fridge won't stay cold. The temp says 56. Ugh! Model # is PLHS67EGSB4.
My Freezer is Cold But My Fridge is Not! - YouTube
? 1:51
www.youtube.com/watch?v=OiKCqniraM8
Nov 5, 2013 - Uploaded by Appliance Princess What to do if your refrigerator is warm, but your freezer is stillcold. ... Cleaning them is a good idea, even if it isn't the cause, because it will improve the fridge's efficiency. ... How does thefreezer fan's failure cause a fridge not to stay cold? .... How To Fix Your Fridgidaire Refrigerator (if the compressor won't ..
Sep 23, 2015 | Refrigerators
Why is the refrigerator not cold, but cool?
If freezer is working & refri.not check damper vent could be frozen or closed
May 07, 2015 | Refrigerators
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
I have a wine chiller which is not refrigerating. The red light in the back is still lite but temperature is 60 degrees and should be 54. I purchased the product in 2007 and wondered if this is an easy fix...
There are many different causes behind machine not cooling. 1. Defrost can be the cause for your refrigerator notcooling problem. To check to see if you have a defrost problem, look in thefreezer to see if there is ice build up on the evaporator cover. (Theevaporator covers are either in the back of the freezer or on the bottom of thefreezer). 2. If the condenser fan (the one under refrigerator) is notworking, the compressor will cut off on the overload. If the evaporator fan isnot running, there will be no airflow to the machine. First walk up to therefrigerator and listen to see if the fans (one in the freezer on one under thebottom) are running. If one is running and the other is not then get to the onethat is not running and see if something is blocking it. If there is nothingblocking it then replace it. 3. Dirty condenser can be the cause for your refrigeratornot cooling problem. If the condenser is dirty, the compressor will cut off onthe overload. If theseparts working correctly, then probably the compressor itself is faulty. You needto replace it. Hope this will help you. Good Luck.
Aug 25, 2011 | Franklin Industries Refrigerators
Referigerator is not getting very cold and the freezer is frosting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 21, 2010 | Whirlpool ET0WSRXML Top Freezer...
2007 F-150 A/C does not blow real cold air. Two separate dealers have told me that is as good as it gets. Is there a booster i can buy?
No booster you can buy, but you can bring it to a real a/c service shop other then the dealer. They can vacuum out the system and replace the accumulator (dryer) which will give it a better cooling performance. Good luck and hope this helps, the high side should be 200 to 300psi and the low side should be 25 to 35psi on a hot day like 85 degrees out side, and the cabin vent should be around 45 degrees.
Jul 11, 2009 | 2007 Ford F-150 Harley Davidson
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
Jun 24, 2009 | LG LRTP1231W Top Freezer Refrigerator
Samsung refrigerator Not cooling below 45 degrees
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
dffg
Mar 14, 2009 | Samsung RF265AA Bottom Freezer French Door...
Undependable freezing - sometimes will, sometimes won't!
High room temperatures will throw this unit off BIG TIME. Just to give you an idea how sensitive the freezer bowl is - if you run cold water along the freezer bowl before putting your ingredients in, the COLD water is enough to unfreeze the bowl! Don't remove the freezer bowl from freezer until you are immediately ready to begin mixing - not 5 minutes earlier.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Dec 02, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Open Questions:
Two door built-in BOSCH [B36IT] fridge with bottom freezer drawer. Inside the fridge, water is leaking 2-3 times per day from the top right corner of the fridge inside wall. I believe the frequency coincides with the defrost cycles. I suspect that the drain tube or channel is clogged. So, I opened the inside panels to investigate, inserted a nylon coated steel cable into the drain hole. I pushed the cable as far as I could, probably 4-5 feet into the channel. The cable seemed to meet a solid end and could not go any further. I repeated this exercise for 2-3 times. Then, I slowly pour some water into the drain hole. After about a quarter cup of water, the water overflowed. Due to the weight and size of this fridge, I have not investigated the back of the fridge, yet. Removing the bottom drawer appears to be a very difficult task also. I plan to search and gather as much information as possible before attempting to pursue further. I watched an online video regarding a Whirlpool fridge. At the back of the fridge, the owner was showing a rubber grommet fitted on the end of the drain tube. The grommet has a very narrow slit opening, similar to a duckbill. It appears that small debris can build up and block the funnel end easily. I have some questions for the experts here: 1 Does the BOSCH fridge drain tube have a p-trap? 2 Do the BOSCH fridges also built with a similar grommet at the end of the drain tube above the drain tray? Thanks!
Oct 05, 2018 | Whirlpool Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
