Question about Indesit W 123 Front Load Washer
Washer is not filling up
The water comes out us soon as it gets in
  • 1,314 Answers
Your drain hose is too far down in the stand pipe or is below the tub and is siphoning the water out soon as it fills pull the drain hose up should only be four or 5 inches in the stand pipe
Posted on Jan 20, 2008
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
Water large amounts on floor of shut off machine
To sufficiently inspect your washer to determine where to leak may be coming from, please review the following link:
If there is a huge gush of water coming from the washer as soon as you begin the fill cycle, this is commonly caused by a small air hose on the side of the washer drum that connects to the pressure switch. If this air hose comes loose,the water will pour from the wash tub as it begins to fill. This is an easy fix, if that is the only problem.
Another cause, can be a water inlet valve that is leaking by, or a pressure switch that does not keep the water supply shut off when not in use. This will cause the tub to fill up and spill over. The following link explains how to check for this as well:
Read through the information provided and let me know if you are having problems determining the cause of your problem. Please post back with your MODEL NUMBER so that I may be able to accurately determine how your washer is configured. I hope you find this information helpful.
Mar 01, 2010 | Kenmore 44102 Front Load Washer
My whirl pool washing machine tries to fill up but never fills up
This means it is stuck between the spin and rinse cycle and the time piece in the housing unit might need replaced if the knob itself isnt stripped also make sure it is on small or large load..
Dec 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. back
Apr 14, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Indesit W 123 Front Load Washer Logo
47 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
