Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Wont discharge water - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
  • 701 Answers
That means that the pump belt is worn or stretched and needs to be replaced. Here is a link to the belt you need and the manual which has instructions:
Bissell ProHeat Belt and Manual
Posted on Dec 13, 2009
Why will my Samsung 400RHS diswasher will not drain?
you may have a clogged line in the discharge hose and pipe to the drain. if not do you here the discharge pump come on and try to pump out the water. could be that you need to replace pump
May 26, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
My Bissell PowerSteamer 1697 series won't discharge water. At first it was just the vacuum art now its also the handtool.
You may have problems with your pump belt, gaskets, or tank. Use this link to determine the exact tip to fix your unit: http://www.bissell.com/FAQDetail.aspx?id=1065
If these don't help, please take your unit to a service center for diagnosis and repair. You can visit a BISSELL Authorized Service Center by locating one here: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50
Sep 30, 2012 | Vacuums
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
I need to know which water lines go to and from pump on bissellporheat steam cleaner? mod.#1699R
The plastic screw-on cap for the fresh water/solution tank has a tiny internal spring loaded plunger that looks like an "X" when viewed from the end. There is a donut type rubber gasket that goes on the end of this screw-on cap. I had reseated this donut gasket but the rim interferred with the plunger so it discharged when I pressed the tank into position. When I got the donut gasket reseated properly, leaking was solved.
May 24, 2011 | Vacuums
I have a Franke Flair espresso machine. Newly acquired from an internet auction. It asks to fill the tank and then to "Fill System // Press Rinse" .. After Pressing the Rinse button, it...
You were sold a dud, these machines are renowned for this problem, try and get a refund or your best bet would be to put it back on the auction site if your conscious will let you.
Feb 04, 2018 | Vacuums
I replace the pump. How do i prime the pump?
Use a hose or bucket. Fill the pump body and the entire suction line (if possible) with water. Close all covers and keep the discharge of the pump open so it can vent any air. Once you are sure that the pump body is full, turn on the pump keeping the suction line under water.
Gary
Apr 19, 2011 | Bissell 8910 ProHeat Clear View Upright...
My Bissell 2x will not discharge soap and water to shampoo my carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
zczv
Jul 28, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water not ejecting from tank
if the solevant tank rubber is on the machine and not the tank cap of distorted than the valve won't open sothe tank discharge won't work
Nov 25, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water will not discharge fo rinse cycle
heatman101
jhj
May 11, 2009 | Bissell 8910 ProHeat Clear View Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
275 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
