Question about Sport & Outdoor - Others
Having problem registering and activating skycaddie sg5 golf range finder
  • 10,515 Answers
I have seen Few Issue's with this. You could only try Few Tricks, if that would work.Turn OFF Anti-Virus and Firewall as it could stop you Registering on that Site. Reinstall the Software and then try to Register.
If unable, try to Register on a Different Machine. If still problem remains the same, contact Technical Support - Skycaddie to register your Complaint. It could be a Server Down issue or Web Site Security issue which they need to check from there side.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
When I turn on my skycaddie at the golf course or at home , I geta message, could not start Application
Are you sure you have registered the device with Skycaddie? If not theedsahe will continue to appear.
I would call them make sure you have all the information they will need on hand (model number, etc).
They are very helpful and can even download the course there and then to your device for you if it is not all ready loaded. Hope this helps.
Jan 15, 2015 | SkyGolf SkyCaddie Handheld GPS Unit
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Registration
Where do I find Caddiesync>
May 28, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
Cant get past personal info page to activate skycaddie golf range finder
Prior to activating your SkyCaddie, you will first need to install a simple software program to your Windows-compatible PC. This software program, referred to as SkyCaddie Desktop, will allow your SkyCaddie to communicate with the SkyGolf website. This program allows you to DirectConnect with the SkyGolf website, so you can personalize your SkyCaddie, download courses and periodically update your SkyCaddie’s software. NOTE: If your computer is protected by a firewall, it may need to be set up to allow our SkyCaddie software programs to access the web. If your firewall software displays any warning messages during the activation process, simply indicate that you wish to allow access. if the software is not installed the unit will not get activated Activating Your SkyCaddie Within 30 days, please register your SkyCaddie, create a “My SkyCaddie” online account and select a SkyPlayer Club Membership Plan by going to the SkyGolf website at www.skygolf.com. Click the “Getting Started” link for information and instructions to complete the process. During this process you will be asked to create a user name and password for your online account referred to as “My SkyCaddie”. The “My SkyCaddie” online account offers a full range of member services, easy access to download courses, support and more. In addition to creating an account, you will be asked to select a SkyPlayer Club Membership Plan that best fits your needs. click this link directly to get more details http://service.alan-electronics.de/golf-electronic/sky-caddie/SG-2-UserGuide.pdf check out on page number 8 of the link to get details on this isue. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 19, 2009 | GPS
Cant get past personal info page to activate sky caddie sg5 golf range finder!get to entering username or password.then after a while it says skycaddie sync not responding
Well first of all you can try to reset your caddie, just remove the battery for 5 hours and insert them again, check again after resetting it......, to reset your caddie there is also a "reset to factory default" option go to main menu then settings then select restore option......
post comments if further you have the same problem....
Good Luck!!
Thanks
Dec 14, 2009 | Sport & Outdoor - Others
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Sport & Outdoor - Others Logo
97 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
