Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer does not shut off / timer does not advance
GE Electric Model # DDE5900RALWH
    Scholar:
  • 66 Answers
Unfortunately this usually means that the actual timer mechanism is bad within the machine. This is not something you can fix and will require a new mechanism which you can either have a repairman come and install or buy a new one at an appliance part shop and install yourself. Installation of a new timer is fairly simple and should only require a flat tip and phillips head screwdrivers and about 15 minutes.
Posted on Dec 12, 2009
SOURCE:
Automatic timer does not advance but timed heat does advance .?
Unplug the unit from the power, or shut off the breaker. Open the unit and check that all wires are firmly connected, no loose ends or broken wires. If all connects seem tight and the wires are in good condition You may need to replace the timer switch. The link below is for the users/owners manual for your machine:
http://www.manualslib.com/manual/251416/Ge-Dbsr453ebww.html
Jun 19, 2014 | GE DBSR453EBWW Electric Dryer
Why won't my GE electric dryer shut off? My GE
The model number you submitted is not valid. Long dry times and dryer not shutting off is either an element problem, an air flow problem. Lets begin with a good model number so we can see your unit as you do...
Waiting to hear from you,Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
Apr 20, 2012 | GE Dryers
Timer counts down but doesnt shut off
same problem with Kenmore dryer Model No. 110.96250100. The timer would not advance under any setting. I replaced the timer and it only advances under timed dry but does not shut off when it times out. Under all other settings, the timer knob does not move, but the temperature stays warm. I checked the continuity on thermostats and resistor and, to the best of my knowledge, all passed. all in all, it appears to be a mechanical problem with your timer.
Please remember to award your selected response
Jan 11, 2011 | GE DNCD450EA Electric Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Dryer won't shut off. Heats fine. Timer advances on air dry only. Vent is not clogged. Can't find moisture sensor replacement part.
https://www.repairclinic.com/Shop-For-Parts/a8b104d87061/Model-CYE2000AYW-Magic-Chef-Dryer-Parts
The dryer requires cycling of the heat to advance thhe timer on auto dry cycle. see ,link provided parts and repair guidance. Always remove from power supply first.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 30, 2017 | Magic Chef CYE2000 Electric Commercial...
Dryer does not automatically stop, takes too long also.
you need a timer you can probably take the old timer in to your local appliance part store and get a new one
Apr 20, 2009 | General Electric DHDSR46EGWW Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Timer doesn't shut down dryer machine
the timer is easy to change, check how much it is first, mine was around $100.
Apr 28, 2008 | Kenmore 62602 Electric Dryer
GE GAS DRYER DCLR333ETOWW
Check the vent sometimes if the vent is blocked the thermostat gets false reading.There are some other problems such as thermostat,Igniter,heating element.
Apr 21, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
218 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
