Question about Trendware TEW-432BRP 54Mbps Wireless Firewall Router
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old pc, but the setup was done by our IT guy. the old laptop says it is connected to trendnet with great signal but the internet connection does not work. the new laptop will not install the trendnet software (as i have read because it is a wireless connection adn their is no additional router). so it tells me to log on manually to configure the router BUT using the ip address of the router 192.168.1.1 nothing comes up on either computer. i called trendnet but they say it is not possible to work BUT i know it does although it's sticky setting it up - i remember our IT guy saying that. can you help?
  • Trendware Master
  • 4,221 Answers
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Posted on Mar 18, 2017
jsbasrao
  • 54 Answers
SOURCE: TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Posted on Mar 20, 2009
raffaiel
  • 209 Answers
SOURCE: Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Posted on Apr 26, 2009
  • 10 Answers
SOURCE: trendnet router tew-432brp
the best thing to do is go to there website and call their tech support.. theyre actually pretty good!!.. cause i have the same brand of router but different model.. i called them and they'll walk you through it..
Posted on May 07, 2009
SOURCE: Trendnet TEW-432BRP wireless router doesn't connect to internet
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. Dont use the setup cd, sometimes it works, sometimes its not. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Posted on Aug 17, 2009
SOURCE: how can I set up a speed stream 4100 modem/router
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the trendnet router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the trendnet router and the other end to the lan port of your computer..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe. Im sure if the computer is connected to the speed stream 4100 modem router you can have an internet access. just in case u did a pppoe settings on the trendnet router and ur done setting the router, u did the connection, then u dont have an internet, set the speedstream modem router to bridge mode
1. click on start
2. run
3. type cmd
Posted on Aug 30, 2009
I purchased a wireless router from a yard sale. and need a network to connect to another computer of mine can you help
installing a network
requirmenst rj45 crimping tools and UTP cable
before u crimp the rj45 must fallow the color coding
white orange
orange
white green
creating a workgroup for file and printer sharing
visit this link for window xp
http://reviews.cnet.com/4520-11334_7-6232456-3.html
http://www.home-network-help.com/set-computer-name.html
for window 7
http://windows.microsoft.com/en-US/windows7/Join-or-create-a-workgroup
note all workgroup name should be same
ex.. (you computer1) computer "name is: com1" workgroup is: maywrkgroup"
( your computer 2) computer "name is: com2" workgroup is: maywrkgroup"
May 27, 2011 | Trendware TRENDnet TEW-432BRP 54Mbps...
How properly to connect TRENDnet TEW-432BRP to laptop
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 26, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
Oct 14, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Wish to setup hp k550dtn printer with ethernet support to a wireless trendnet router..432BRP. Two laptops will share this printer
You can use a print server to connect your printer to your computers over the ethernet/wifi connection, All printers will be using a network printer..
OR..
You can Attach the printer onto 1 of your computers, set the properties to share the printer, and then set up a new printer on the other computers (network printer)
Make sure all the computers on your home network are on the same WORKGROUP
Jul 17, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Trendnet router tew-432brp
May 07, 2009 | Trendware TEW-432BRP 54Mbps Wireless...
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
smeags.
Jan 08, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TEW-432BRP 54Mbps Wireless Firewall Router Logo
103 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
