Question about Toshiba Satellite 1800-S253 Notebook
We have a second hand one of these with a password still in progress. how do I rest the password
    Novelist:
    Champion:
  • 226 Answers
BIOS passwords on these things can be removed with one of 'em parallel port password removal device/gadgets. Or you can make your own - the schematics is available on the internet.
Once you have the gadget, or gizmo, plug it into the parallel port, turn the machine on, and the BIOS password will be gone.
Posted on Mar 16, 2010
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
May 03, 2015 | Invicta Watches
How long does the soft heat wrap ultra need to be microwaved
Typically, for anything, I try 15 seconds (below 100g ), if not sufficient 30 seconds and progressively more as function of weight ( one to two minutes for 300g) , testing the not burning temperature with your hand.
It is very burning to try several minutes abruptly without testing progressively. You can even have explosions, in particular with eggs !!
Feb 13, 2014 | Kaz SoftHeat Ultra Back and Hip Wrap
My watch will work as a stopwatch but the time will not progress and I am not sure if it a battery or mechanism issue
Yes it is not a battery problem , you say the second hand remains static therefore I presume the other hand is moving ? if this is the case it might be because the second hand is not attached to the shaft properly although you say you can set the time and it will work for a short period and then fail it still might be the case which is a fairly simple job , hopefully it is not in the watch mechanism that causes it to not work .
Nov 10, 2017 | Chase TX TechnoLuxury - 800 Series: Linear...
Progress: -------------------------------------------------------------------------- Checking Http URL: http://87.56.179.75:8888 ... Error! Checking Stream URL: http://87.56.179.75:8081 ... Error!...
Hi friend,
We have to open the port numbers in your router for the above eroor check sum,follow the below mentioened steps,
1.Type 192.168.2.1 in the Internet explorer,You will get a belkin router setup page
2.On your left hand side,click on Firewall,it will ask for password,leave it blank and click submit
3.Change it to disabled and click on Apply changes
4.On your left hand side click on Virtual servers
5.Put a "Check mark in 1st box",in "description type as Streaming" in "Inbound port put the numbers 8888" and in the "type select as TCP and UDP" and in "the Private IP address type the ip address of your particular computer in which you are getting this error message" and the Last Outbound port,type the number 8888"
6.The same for the second one but the Type is TCP and the Inbound and outbound port is 8081
If u have any clarification feel free to provide th reply
Regards,
Ayyasam
Feb 27, 2010 | Computers & Internet
How can get my gamertag back after getting a new ps3 as i got it second hand from game station and its broke and i dont want to lose my modern warfare progress ?
All u need to do is enter ur email and password into the sign in if the sign in is not there u have to go to playstation network button where sign in normal is and go to use existing user account.
Feb 02, 2010 | Sony PlayStation 3 40GB System
How to, password rest
Depending on the router there will be a reset button on the back of the router. Its a pin hole sized button. Use a paper clip to hold it down. Reboot the router and you should be back to the default settings
Nov 10, 2009 | Computers & Internet
I forgot the password for mine, how can i get around this to cancel or even change the passwprd?
If you have forgotten your password you should be able to use the password hint to figure out what it is. You can try a soft reset to see if that will clear the password but I am pretty sure this won't help. To do a soft reset use the tip of the stylus or something pointed like a paper clip and inset it in the hole on the back of your palm pilot. This will make the unit reset it's self. If this doesn't help then you must preform a Hard rest to continuing using your hand held. You need to make sure that you have all your information backed up on your computer as a hard reset will erase everything on your hand held. Here are the steps to do a hard reset:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Aug 05, 2009 | Palm TX Handheld
I want to know the ip config for this brand i have 15 computer
Hold down the rest switch on the back for 30 seconds. Go to start, run, type in cmd and hit enter. When the dos screen comes up type in ipconfig. This should give you the gateway address for the router. I think the standard ip for dlink is 192.168.0.1
May 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Toshiba Satellite 1800-S253 Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
