Question about D-Link Xtreme N DIR-655 Wireless Router
I set up my d-link dir 655 without requiring a password for access. To protect my access, I want to require a password and cannot find out how to do it.
    Sergeant:
    Champion:
  • 232 Answers
Download the manual here http://www.dlink.com/products/default.aspx?pid=DIR-655&tab=3 and look on page 64. It goes through the wireless security wazard.
Posted on Dec 12, 2009
I have a dlink dir 655 and lost my password. how can i get a new one?
For setting up your resetting d-link router password you have to follow these steps..
1. open your browser and type 192.168.1.0 and type user name and password
2.go to wireless settings and setup ssid ( network name ) and password
3. than click save and apply for more technical help you may can contact d-link Tech Support
i hope this will help you thanks
Oct 04, 2013 | D-Link Xtreme N DIR-655 Wireless Router
I lost my password
Take look at the following link. This will reset your 655 to the factory defaults (including the password).
NOTE: You will lose any settings you have made, and will have to redo them.
http://www.dlink.cc/d-link-router/dir-655-forget-password-and-how-to-reset-it-back-to-the-factory-default-settings.html
Sep 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Making my computor secure
Keep the computer in a secure room or cabinet to prevent unauthorized physical access.
Require all users to enter a complex password to logon to the computer.
Install security software to protect against viruses and malicious software and make sure you keep it up to date.
Enable the firewall on your computer or use security software that includes a firewall.
Install critical and security updates for your operating system and keep it updated.
Use a wired connection to the Internet instead of wireless which can be hacked.
If you must use wireless then use WPA2 encryption. All others can be easily hacked. Require a complex password for the wireless password, hide the wireless network ID (SSID) so no one can see it and, if possible, configure the router to only allow specific computers to connect. This is called MAC filtering.
If this helps please vote for my solution.
Nov 20, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Wireless security
Hi, The program is already set by default. Once into the set up [ please read instructions - it is easy ] - select security enable and then choose what type of security you want WEP is the most common. YES it is VERY possible but will require some reading on your part.
May 08, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Lost my d-link dir-655 quick router setup wizard CD, can i get one?
Are you trying to set up the router?
you don't require the CD.
You can change the settings of the router manually also.
Click Here for more info about the router set up
Oct 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Work as acsess point
first let's back up and get the terminology right (otherwise you will not find any information on the internet.)
Your 655 will be the Access point, because it gives access to the wired WAN (ISP, Internet, etc.), or 'outside world".
Your 635 will be called a Bridge, because it bridges the connection from the access point to other wired or wireless clients inside your own network.
If this mode is accessible for you depends on the firmware you have installed. Look at this posting.
Your D-Link 635 is unfortunately not compatible with other firmware, which would be necessary to convert it into a bridge. (See here)
Sorry - but that's the reason why so many people get a Linksys or Buffalo router.
Also - the distance of 500 meters (open air or not) requires an increased transmitting power from the access point (655) and you will have to use different antennas. Third-party firmware also allows you to modify the standard power settings, but you have to make sure that you stay within legal limits of the place where you set this up. If your signal interferes with someone else's, you might get into trouble or even get a fine.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 30, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DIR 655- losing connection with ntwk is "INVISIBLE"
unfortunatly it is my understandingthat blackberrys require an ssid to connect as they are not as advanced as a laptop or wireless adapter on a pc...sorry
Dec 11, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
371 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
