Question about Zanussi TC7114W Electric Dryer
Dryer powers up but won't start - smell of electrical burning. Is it the motor bushes? zanussi TC7103W
    Novelist:
  • 195 Answers
Electric dryers usually have a motor with a switch that prevents the heating element from being powered until the motor is spinning. In series with this are limit switches to prevent overheating if there is too much lint or too little air flow around the heating element. Also, the motors are induction or brushless. So the smell is coming from the heating element burning off some lint nearby as it reaches the high limit temperature and shuts off. This can be due to two conditions if we can assume the motor is running (has a switch that is closing to power the heating element). The most likely condition is that the drive belt is off the pulley or broken and the drum is not turning. You will be able to tell this easily by sounds or by opening the door to see the drum slowing down. If that's not it, examine the blower which forces air through the drum. There are a lot of variations, so look for air intake and drum exhaust ports that can be clogged with a sock, lint, etc.
Posted on Dec 12, 2009
Where does the tension spring go on a zanussi tc7103w?
Needs to be hooked on to motor so there is lots of tension pulling on the motor.if i remember correctly there is a long thin bolt holding the motor together and this is the place to attach spring. Hope this helped Tim
Apr 21, 2011 | Zanussi Dryers
The drum wont go around and it smells like its burning.
if you can turn the drum by hand it may be the motor start capacitor.fitted just above the motor if you cant turn the drum one of the drum seals will have jammed the drum the belt will have snapped as well.
Aug 06, 2010 | Zanussi TD4112W Electric Dryer
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
Zanussi tumbledrier TC7103W not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Aug 30, 2009 | Zanussi TC7114W Electric Dryer
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 17, 2009 | Zanussi TC7114W Electric Dryer
Zanussi tumble dryer model TC7103W ** heat, machine runns ok, changed compleate heater unit including thermostat.
it could be the timer what sometimes happens is a wire can burn out or have a break in it have had some dryers do this to me and have had to change part of the wiring to fix the customers dryer
Mar 10, 2008 | Dryers
TC7103W - electric dryer
there is a lint blockage between the water collection box and the pump
Jun 02, 2007 | Zanussi TC7114W Electric Dryer
My zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Mar 06, 2007 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
410 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
AZBen
AZBen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
