I have a d52s20. I have replaced cp 120, CP 150, & CP 114. The TV clicked and tryed to turn on in the first cycle on the third try pop CP 120 blows again for the third time. Is there any fuses that I need to replace and where are they located? Also I have not seen any broken solder points on the flyback board. Please help. Thanks
  • 5,138 Answers
You must have put capacitor in backwards that would cause it to blow up make sure you have Neg- and postive+ in right!
Posted on Dec 12, 2009
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca hdtv monitor power flashes 3 times after pushing it and tv does not turn on.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. 3 blinks occur if any of them is puffed up on top. To resolve this issue you'll have to replace all the 3 capacitors CP150 2200UF 16, other 2 are 220UF 35v they will be green with gold writing on them. Also re solder all pins on Fly Back Transformer (FBT). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 10, 2010 | RCA R52WM24 52" HDTV Projection Television
Replaced cp150 @cp114 plus flyback. tv runs great but not full screen.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If you have already replaced two of them then replace CP 120: 330UF/35V/HF and post back if that makes any difference.
Thanks Rylee
Jun 05, 2010 | RCA D52W19 52" Rear Projection Television
The tv will not power up. Blinks three times and shuts down. TL010 shorted ,replaced but still has problem.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If any of them is puffed up on top replace all the 3 capacitors CP150 2200UF 16 other 2 are 220UF 35v they will be green with gold writing on them. Resolder all pins on Fly Back Transformer (FBT) also. FBT could be in the power supply. Check the SMPS and in any event replace CP 120: 330UF/35V/HF & CP 150: 2200UF/16V/HF (May be bulged or vented)
Always Resolder Cl031 & Cl032 (usually looks ok on visual inspection but common to ring crack).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Have a hard time turning on my TV, have a RCA big
there are caps in the smps board that require replacment cp 150 cp 120 cp114 and check solder connections at clo32
Oct 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
With tv on it turns off and the back about 3x then is done
on the itc board change
1.flyback
2.cp 150,cp 114,cp 120 and cl 031......
it should work...parts cost about $30.00 total
Mar 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback replaced
your flyback should still be good get the other parts changed out and go from there
Dec 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
ck cp 150 2200uf 16v cp 111 220uf 35v and cp 114 220 or 330uf 35v replace all 3 capacitors
Nov 26, 2008 | RCA D52W19 52" Rear Projection Television
Capacitors
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Nov 05, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
