Question about Microsoft Xbox 360 Console
I got the E74 message on my xbox this morning but i noticed that when i had my xbox on without the av composite cable in there was no lights flashing red so does anyone know weather it just is the cable itself or the component inside the xbox
    Genius:
  • 1,093 Answers
If you have the E74 message this is because the scaler chip that deals with the display has overheated and you need to get this fixed, you can do this yourself with a good Xbox 360 Repair guide or send it in.
If you send it in it might not get back to you until after Xmas now.
Hope this helps!
Posted on Dec 12, 2009
    Sergeant:
    Champion:
  • 232 Answers
I had the exact same problem. Tried another AV cable and another TV an it did the same thing. After a while it came up 'E74 Error' Only way to know for sure is to maybe try your console with a friends set of wires and see what happens.
I Have the E74 Message is there help without spending alot of money?
The E74 message relates to your AV cable. If you can swap it with a different one try that out. There is a chance that the problem is an issue with your scaler chip which is connected directly to the cable. There is also a small chance that your GPU is the problem as well. The best thing to try first though is to swap your AV cable.
Mar 07, 2010 | Microsoft Xbox 360 Console
One red light flashing on xbox360,code e74 showing on screen
If you have 1 red light flashing it is normally E74 or some other E error you need to stop the heat.
You can send it in and Microsoft will do it for you or you can repair it yourself using a good guide
Dec 23, 2009 | Microsoft Xbox 360 Console
Referbed Xbox 360 pro error message E74 what does this mean?
DVD Drive Error - Dvd drive timed out during reset :Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot. also it could mean that the Kernel can't be launched/signature in NAND Flash chip is broken It could be possible after bad update. http://forums.xbox-scene.com/index.php?sho...p;#entry4156375 This might also be caused by a bad SATA cable.
Sep 19, 2009 | Microsoft Xbox 360 Console
E 74
Heres the problem
Section 4 is flashing red
- Hardware Failure
Specifically
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known
to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected
directly to the AV cable) in rare cases it is the GPU.
If changing the cable doesnt work then you will need to get it fixed by Microsoft
Check the documentation that came with your Xbox 360 for contact information.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Aug 24, 2008 | Microsoft Xbox 360 Console
One red flashing light e74 rror code
If you just got it take it back, if you have had it for a little while you need to call microsoft and send it off for repair
Aug 21, 2008 | Microsoft Xbox 360 Console
E 74 error
Here's your problem
hope that helps
E74
There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement
so since you ruled out the av cable then it comes down to the scaler chip problem.
Contact microsoft and get it replaced, another thing you could do is if you have a multi-meter is use that on the output cables of the xbox it will register with some current 5w or so I think it is not 100% sure of that tho I would have to test to make sure.
But as far as a fix for the scaler chip. your best bet would be to call xbox In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
That way if any warrenty on it is not void, and you can get it fixed for free and they are very prompt with their fixing.
hope that helps
Aug 01, 2008 | Microsoft Xbox 360 Console
XBOX 360
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)
Jun 10, 2008 | Microsoft Xbox 360 Console
E74 Message
An E74 error usually means there is a problem with the AV cable but in rare cases could also mean there is a problem with the GPU. If you can, try and use another AV cable, pick one up second hand and see how it goes.
Please rate if at all useful, thanks!
Apr 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
