Question about Logitech USB Desktop Consumer Microphone
Mic filter Does logitech make a filter for its microphone or can I make a homemade one. Maybe I'm to close to the mic when I am recording. Not sure.
  • gwoodard0349 Mar 12, 2008
    I bought a better mic.
  • 4 Answers
You can take a filter from an old speaker and arrange it in front of your mic.
Posted on Mar 12, 2008
Mic not working!
Go to logitech's website and look for the latest driver for your microphone:
Install it, plug in mic, load audacity/garageband, or any windows recording application, and ensure the mic input on the application is set to the plugged in logitech/labtec mic. Ensure the input volume is set to a level that responds when speaking into mic. Press record to see if it picks up the audio.
Apr 13, 2012 | Audio Players & Recorders
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
Microphone doesn't work on Logitech ClearChat Premium PC headset. I've checked jacks, mute switch. Ran Paretologic to install proper drivers. Is there an on and off switch for the microphone (not the...
If the mic mute switch is not on and there is no red light in the mic arm then its likely you have a check in the 'mute mic' box in your sound manager. Open Volume control, choose options->properties-> recording. Check for checks in the boxes and remove them. Also make sure the slider for the mic is about half way up.
Mar 19, 2010 | Logitech (980240-0403) Microphone
Logitech USB Desktop Microphone. I have Windows Vista. Followed install directions even though outdated. Looks like it is recording, and can save file, but no sound when playing it.
If there are more than recording device, then you have to select default recording device as you MIC connected to coresponding sound card..
For eg, if your MIC is connected to front panel and if the REAR IN is selected as a default device you wont able to record sound in Windows Vista..
To select default recording device
  1. Select your sound properties through the control panel or the sound icon in your system tray.
  2. Click on the properties tab,Check the recording box.
  3. Make sure you have selected the default device upon mutiple device
Please leave me comment, if you still need furthur assistance
Sep 24, 2009 | Logitech USB Desktop Consumer Microphone
Scratchy mic noice
try to reduce sensitivity of your mic if you can or simply reduce lever of recording which at the same time should reduce sensitivity. ..or get yourself one of cheap logitech mics and record through them
hope this helps
Jul 30, 2009 | Toshiba (P000257700) Microphone
use the wizard in msn and also look sound options maybe the mic is muted. u can try does the mic work or not in sound recorder proram under start menu, the software for logitech u can find from under support
Jan 13, 2009 | Toshiba Satellite M45-S169 Notebook
No sound when connected on aim
Is your microphone integrated into your webcam? Make sure the correct device is selected. Go into Edit, Settings, Enhanced IM. Under Audio and Video, make sure the Microphone device selected is a functioning mic, such as Logitech Mic, or if using a headset, select the USB headset (if usb) or your sound card if using a mic plugged into your built in or add-on sound card.
Dec 01, 2008 | Logitech QuickCam Connect Webcam
Mic not working
The cause of a Web Cam's microphone to stop working can be either a hardware issue or a result from incorrect configurations.
Determine whether it is a hardware problem by testing the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
We also recommend using the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Additional Information:
Multimedia keyboards that have the ability to control your computer volume may have software that can interfere with your webcamera's sound. If you have a Multimedia keyboard with volume control, the keyboard's software may need to be uninstalled in order for the camera's microphone to work properly in Windows.
Please see these related articles as well:
Nov 05, 2008 | Logitech QuickCam Communicate Deluxe...
Logitech microphone stuffed up my Computer Speakers!
go to sound icon in bottom task bar, double click on it,go to options,then properties,then click RECORDING,make sure you have a tick in MIC,then go to back to sound icon in bottom task bar,and adjust mic settings to suit
Sep 19, 2008 | Logitech (980240-0403) Microphone
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
Logitech USB Desktop Consumer Microphone Logo
78 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
