Question about HP Jetdirect 170x Print Server
HP JetDirect J3258B asking for host name
HP JetDirect J3258B asking for previous host name before it will save any TCP/IP config settings. It does not and never did have a host name
    Sergeant:
    Champion:
  • 232 Answers
Question is, if you DO type anything does it save then? I had a similar problem and the box was faulty. Having a host name in their won't stop it from working.
Posted on Dec 12, 2009
SOURCE:
How to assign ip address for laserjet M4345 when it is reset at 0.0.0.0
1 Press MENU.
2 Touch CONFIGURE DEVICE.
3 Touch I/O.
4 Touch EMBEDDED JETDIRECT MENU or EIO JETDIRECT MENU, depending on which type of
network connection you are using.
5 Touch TCP/IP.
6 Touch CONFIG METHOD, and touch MANUAL.
7 Touch MANUAL SETTINGS
8 Touch IP ADDRESS
9 Touch the left arrow or the right arrow to highlight each segment of the IP address.
10 Use the numeric keypad to type the digits in each segment of the IP address.
11 Touch OK to save the IP address.
Sep 16, 2013 | HP LaserJet M4345 MultiFunction Printer
Network can't ping jetdirect 615n card
why not ask at HP and not here, why ask on non HP forum.?
the HP enterpise forum covers this.
ask here first., they will direct you to OLD hardware help.
https://h30434.www3.hp.com/
here im searching there, see all those posts there.
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=JetDirect+615N
Jun 08, 2017 | HP JetDirect 615N J6057A Print Server (In...
Configure ip adress to hp laserjet p3015
This model does actually have embedded network functionallity.
To configure the IP Address, follow the menu map as below:
1) - (4) I/O
2) - (4-2) Embedded JetDirect Menu
3) - (4-2-2) TCP/IP
4) - (4-2-2-1) Enable (Make sure this is 'On')
5) - (4-2-2-3) IPV4 Settings
6) - (4-2-2-3-1) Config Method (Auto = DHCP, Set to Manual in order to specify an IP address.)
7) - (4-2-2-3-2) Manual Settings (This is where you can set the IP Address, Subnet Mask, and Default Gateway.)
Apr 28, 2011 | HP P3015 Laser Printer
Network installation error access denied on hp lj1020 my printer was working fine. i have installed printer on xp m/c its working fine but when i install it on win7 it give error print spooler error or...
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
Dec 19, 2010 | HP LaserJet 1020 Printer
How do I change IP address settings for my HP Laserjet 4650dn printer
Changing the printer's IP address
If the TCP/IP address needs to be changed, the HP Jetdirect can be reset to factory defaults so that it can receive a DHCP configuration from a server (see below). Another method is to use the printer's control panel:
1.Press the green check mark (Select) button.
2.Press the Up or Down arrow to scroll to CONFIGURE DEVICE menu and press the check mark button.
3.Press the Up or Down arrow to scroll to I/O , then press the check mark button.
4.Press the Up or Down arrow to scroll to EIO 1, 2, or 3 (depending on which EIO slot is in), then press the check mark button.
5.Press the Up or Down arrow to scroll to TCP/IP , press the check mark button.
6.Choose Config Method , then press the check mark button.
7.Choose Manual , then press the check mark button. Wait for the display to return to the Config Method screen. A Manual Settings option should now be available.
8.Press the Up or Down arrow to select Manual Settings , then press the check mark button.
9.Press the Up or Down arrow to scroll to IP address , then press the check mark button.
10.Use the Up or Down arrows to choose first byte of IP address. Press the check mark button to save the IP byte.
Repeat for the second, third, and fourth octets.
11.Continue using the Up or Down arrows and the check mark button to enter the Subnet address and the Gateway address.
Aug 18, 2010 | HP LaserJet 4650 Color Printer Manual...
No print outcomes from hp laser jet printer.
Restore Your Printer To Factory Default Setting.
To restore the factory-set defaults
1. Press MENU/ENTER.
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
The device automatically restarts.
Configure the printer as below :
Network configuration
You might need to configure certain network parameters on the printer. You can configure these
parameters from the printer control panel, the embedded Web server, or for most networks, from the
HP Web Jetadmin software.
NOTE For more information about using the embedded Web server, see Using the embedded
Web server.
For a complete list of supported networks and for instructions on configuring network parameters from
software, see the HP Jetdirect Embedded Print Server Administrator’s Guide. The guide comes with
printers in which an HP Jetdirect embedded print server is installed.
Manually configuring TCP/IP parameters from the printer control
panel
Use manual configuration to set an IP address, subnet mask, and default gateway.
Setting an IP address
1. Press Menu.
2. Press to highlight CONFIGURE DEVICE, and then press .
3. Press to highlight I/O, and then press .
4. Press to highlight EMBEDDED JETDIRECT, and then press .
5. Press to highlight TCP/IP, and then press .
6. Press to select CONFIG METHOD.
7. Press to highlight MANUAL, and then press .
8. Press to highlight MANUAL SETTINGS, and then press .
9. Press to highlight IP Address:, and then press .
10. Press the or arrow to increase or decrease the number for the first byte of the IP address.
11. Press to move to the next set of numbers. (Press to move to the previous set of numbers.)
NOTE To cycle through the numbers faster, hold down the arrow button.
12. Repeat steps 10 and 11 until the correct IP address is entered, and then press to save the
setting.
13. Press Menu to return to the Ready state.
Setting the subnet mask
1. Press Menu.
ENWW Ne.
If problem persist , reinstall the drivers .
Aug 07, 2009 | HP LaserJet 3015 All-In-One Printer
Can not print on my ricoh 2018
it sounds as if you have an IP address conflict, are you set to Dynamic or Static? if static set the last Octet ie:192.168.0.xxx to something at the top of your ip range, print out a config sheet from the Copier/MFP by going into user tools printer config page and print.
at the bottom r/h side is the host name of the printer typically with Ricoh it will be Rnpxxxx
set the hostname on your tcp/ip port to the host name ensure that you have dns information set on the MFP and your pc and also gateway info on both and that should fix the issue once your reboot the pc and MFP.
if this resolves your issue please rate me accordingly.
Thanks
Aug 06, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
Select whether the TCP/IP protocol
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
May 26, 2009 | HP LaserJet 4100dtn Printer
Configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Nov 19, 2008 | HP Jetdirect J2552A/B (J2552AB) Print...
How to setup JetDirect Plus (J2591A)
Hi Sam,
I had a similar problem and solved it, so here is a step by step. Connected to a Linksys 54G wirekess router/hub it works fine on Vista and XP, the approach is the same but some windows might look different. You may not even need the HP software at all, as Windows recognizes the HP JetDirect. Also, depending on your PC software configuration, e.g Firewall settings and router settings you may have to permanently permit various communication request. The steps below are to be understood as a guide line and may vary form yours as there are different ways to achieve the settings. On Vista, Telnet is disabled by default and needs to be enabled frist. On XP telnet is enabled by default. If you use a Linksys or similar router, you may need to enable DHCP for some addresses or range that will be used. In such case see you router manual how to do that.
Step 1:
you need to know what your LAN address is, to find out you can open a DOS window and enter IPCONFIG, this will give you the current IP address and subnet mask. On a small home network it may be 192.168.1.xxx and sbunet mask may be 255. 255. 255. 0, yous may be different. Take note of these values (IP: aaa.bbb.ccc.ddd) as you will have to set the HP JetDirect J2591A to the same address range.
Step 2:
connect the printer to the HP JetDirect, have paper in the printer, power the HP JetDirect and hold the test button on the HP JetDirect for about 7 seconds, the printer will then print the current HP JetDirect settings. You may notice the address range the HP JetDirect is set to may not be the same address range as you need it to be (your noted once)
Step 3:
connect a PC computer directly to the HP JetDirect using an Ethernet CROSSOVER cable OR connect a PC via a hub and tow standard Ethernet cables to the HP JetDirect.
Step 4:
TEMPORARELY change this PC computer network address to the same address range as the HP JetDirect address range (www.xxx.yyy.zzz) currently is set to and reboot the PC.
Step 5:
after reboot, the Status LED on the HP JetDirect should be solid on and the activity LED should be off or flashing occasionally, idicating some network traffic. Open a DOS window on the PC and run a telnet session by entering TELNET www.xxx.yyy.zzz [ENTER]. You may have to hit the Enter key tow times for a connection to start. You will then see a screen as follow:
Please type [Return] two times, to initialize telnet configuration
For HELP type "?"
===JetDirect Telnet Configuration===
Present Config : DHCP
MAC Address : 00:60:b0:ab:cb:4e
IP Address : 192.168.1.8
Subnet Mask : 255.255.255.0
Default Gateway : 192.168.1.1
Syslog Server : 0.0.0.0
Idle Timeout : 90 Seconds
Set Cmnty Name : Not Specified
Host Name : HP_PRINTER_SERVER
DHCP Config : Enabled
Passwd : Disabled
Novell : Disabled
DLC/LLC : Disabled
Ethertalk : Disabled
Banner page : Enabled
To Change/Configure Parameters Enter:
Parameter-name: value <Carriage Return>
Parameter-name Type of value
ip: IP-address in dotted notation
subnet-mask: address in dotted notation
default-gw: address in dotted notation
syslog-svr: address in dotted notation
idle-timeout: seconds in integers
set-cmnty-name: alpha-numeric string (32 chars max)
host-name: alpha-numeric string (upper case only, 32 chars max)
dhcp-config: 0 to disable, 1 to enable
novell: 0 to disable, 1 to enable
dlc-llc: 0 to disable, 1 to enable
ethertalk: 0 to disable, 1 to enable
banner: 0 to disable, 1 to enable
Type passwd to change the password.
Type "?" for HELP, "/" for current settings or "quit" to save-and-exit.
Or type "exit" to exit without saving configuration parameter entries
Step 6:
Now you can change (likely neccessary) the HP JetDirect settings, make sure the HP JetDirect IP address is in the same range as you need it to be (for example aaa.bbb.ccc.25), also be sure to set the DHCP Config to Enabled. Optional you may want to enter a Host Name, for example: HP_PRINTER_SERVER, once you are done these new settings must be saved by entering 'quit' [Enter]. You may want to repeat Step 2 and print the new settings to convice youself the settings are retained and correct. (power cycle the JetDirect of course)
Step 7:
Connect your HP JetDirect to the intended network.
Step 8;
On the PC used to do the HP JetDirect configuration setup, restore the PC's initial network IP sddress and reboot it so it can be used again with its original settings.
Step 9:
On a PC connected to the same network as the HP JetDirect, open a DOS window and run a ping by entering: ping aaa.bbb.ccc.25 [Enter] depending on firewall settings you may have to grant permission to allow the ping to come through. You should then see a screen similar to this:
C:UsersHW_Dude>ping 192.168.1.8
Pinging 192.168.1.8 with 32 bytes of data:
Reply from 192.168.1.8: bytes=32 time=5ms TTL=60
Reply from 192.168.1.8: bytes=32 time=3ms TTL=60
Ping statistics for 192.168.1.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 5ms, Average = 3ms
C:UsersHW_Dude>
Note, there are 4 packets send and received without any loss. This is what you expect to see and great confirmation the HP JetDirect is on the network and ready. If you don't get that then there may be an issue with cabling and/or the firewall settings, you may want to double check these in such case.
Step 10:
On any PC connected to this network one can now insatll/connect to the printer that is connected to the HP JetDirect, using the Windows Add Printer Dialog, click to open the add printer wizard. Check the button for LOCAL printer (yes local, not networked !!! Who would have thought of that !? Thanks Bill G.) On the next screen that opens check the 'create new port' option and select 'Standard TCP/IP Port' OR (if available) 'HP Standard TCP/IP Port) and ckick Next. Another windows opens with TCP/IP setup wizard, click Next. An window opens, enter the HP JetDirect IP address (aaa.bbb.ccc.25) and click Next. Follow the Windows guide and finish entering the requested information. You may then want to print a Test Page once the dialog is completed, you may have to permanently allow requested traffic in the firewall settings again.
Step 11:
Your done, congratulations !
Jul 06, 2008 | HP JetDirect EX Plus Print Server
HP Jetdirect 170x Print Server Logo
602 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
