Question about Dewalt DC616KA 18 - Volt 16 - gauge Straight Finish Nailer Kit
I have only used my Dewalt DC616KA Finish Nailer for one Project. I finshed some crown molding in my bathroom and trimmed 12 interior doors. Now it will leave about a 1/4 inch of the nail exposed no matter what seeting it is at. This is somewhat random but in the wrong way. Every now and then it does one right. The head light does blink as though the battery is low. However I took the nailer to a job sight and tried several fully charged batteries and got the same result. I have only put about 500 to 600 nails through it. Can you tell what the problem might be?
  • 33 Answers
If its even close to being under warranty your local dewalt service center might be agreeable to taking care of it for you if you ask nicely :)
the driver blade may be bent/broken or one of the multiple plastic pieces inside may have cracked or chipped, keeping the driver from travelling the full distance. the blade fits into the "profile" which may be somehow damaged or worn to the point of malfunction. there are two bumpers that fit on the profile and these may have slipped, cracked, etc.
even if none of these parts are so damaged as to be defective, even a tiny piece chipped off could be impeding the function of the assembly. but my guess is that's where your problem is.
Posted on Dec 14, 2009
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Jun 07, 2015 | 2006 Chevrolet Tahoe
Dewalt 51256 finish nailer, 16 gauge. Shoots two brads at same time. Using Porter 16 gauge brads. Any suggestions
Replace the trigger valve part # 647956-00 to solve this problem. If you have access to very small orings (2mm x 1.5mm), try replacing the two orings on the trigger valve stem. Dewalt uses vinyl orings on the trigger stem and they fail causing malfunction. Easy fix however and not expensive . Good luck
Feb 24, 2014 | Dewalt D51256K 16 gauge finish nailer kit
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
My DiWalt 16 guage cordless nailer will not cycle or turn on when I compress the tip to fire a nail. May have bumped the tip while putting it away. Was working fine and then just stopped. Repair shop say...
I would not try and repair this yourself. They are a nightmare to work on and I have been repairing construction tools for 20 years. The reason they want you to authorize up to $200 is because the GRC on this tool through DeWalt is $199. That means that if you take it to, or send it to a DeWalt service center (actual DeWalt, not just and authorized repair shop) they will fix whatever it needs and the price will not exceed $199 no matter how many parts it needs. Here is a link to the parts diagram if you want to see what they are link.
http://servicenet.dewalt.com/Products/Detail/DC616KA
Jul 24, 2011 | Dewalt DC616 16g Cordless 18v Straight...
The gun dose not fire the pin all the way in ?
Dewalt list the obvious causes below.
Remember that the gun may not facilitate the use on specific materials that are just too much for the gun to handle. The most common cause for this issue is depth adjustment is not set properly. Also make sure that the nails being used are the correct nails for the gun. Its possible to buy the wrong type and they look very similar to the ones needed.
Here is The website addy for Dewalts pdf user manual and tech tips.
http://servicenet.dewalt.com/Products/Detail?productNumber=DC616KA#
Low battery charge or damaged battery Charge or replace battery
Depth adjustment set too shallow Rotate depth adjustment wheel to a deeper setting
Tool not firmly applied to workpiece See instruction manual
Material and fastener length Choose appropriate material or fastener length
too rigorous an application
Damaged or worn driver blade tip Replace driver/return assembly; see authorized service center
Damaged or worn driver/return assembly
Mar 08, 2011 | Dewalt DC616KA 18 - Volt 16 - gauge...
When battery gets plugged in lights come on but nailer wont fire
Does the motor run but does not fire a nail? If this is the case chances are the belt came off the flywheel. This is one of the most common problems when these will not fire.
If the headlights go on but the motor does not run it could be a bad switch or contact trip.
This a PDF of the owners manual, Page 9 had some trouble shooting tips. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/644429-00,DC612.pdf
This is an exploded view of the tool http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=34790&typeId=9472&documentId=23898
From www,dewaltservicenet.com you can get the contact info for you local Factory Service Center if needed.
For safety remember to always remove the battery when performing any service to this tool.
Oct 10, 2010 | Dewalt DC616KA 18 - Volt 16 - gauge...
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
How to remove the door panel on a 96 Ford Thunderbird?
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Feb 21, 2009 | 1996 Ford Thunderbird LX
ONLY SHOOTS ALL THE WAY PART TIME
Okay you could have a couple problems there are power bands that retract the driver. They are under the front cover. Also the is a part called a profile and driver that actually drives the driver and pushing the nail into the wood. I had one that seemed to work OK but wouldn't drive completely as you describe and I had to replace the profile and driver. If you are uncomfortable with this type of repair I would suggest taking it to a DeWalt store and having them fix it. They have a max repair rate and will replace everything that is wrong including batterys if need be for one price. But before you attempt any repairs I would go to the DeWalt website and get a copy of the breakdown first. Good luck and let me know.
Dave
Dec 15, 2008 | Dewalt DC616KA 18 - Volt 16 - gauge...
Dewalt DC616KA 18 - Volt 16 - gauge Straight Finish Nailer Kit Logo
285 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
