Question about Refrigerators
Maytag refrigerator msb2354drw
Periodic clicking sound. Happens every1-2 minutes in a sreies of 2 clicks.
Why?
  • pearsondp2 Feb 11, 2009
    the fridge started by clicking on and off and now its not working at all. if you switch on it clicks once and them compressor goes off completely.
  • robert samples May 11, 2010
    is it cooling
watugot
  • 290 Answers
SOURCE: Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
Posted on Dec 07, 2007
mikedurland
  • 481 Answers
SOURCE: maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 06, 2008
SOURCE: Maytag refrigerator clicking noise and stopped working
Mine is P mds2651 HEB.
Same Problem.
Home Depot and Maytag ****.
Posted on Aug 20, 2008
aborcass
  • 2651 Answers
SOURCE: maytag msd2756de side-by-side: loud clicking noise from top right of refrigerator
sounds like the adaptive defrost controller part number 61005988. not to bad to repace, the top control panel is removed by pulling down on both rear corners ( youls find little finger holes across the top rear panel to free and pulll foward, the n there are 2 1/4in screws across th efron of control, and 2 phillips head screws jus behind each light bulb, one last 1/4in screw directly on back wall will drop entire panel adn after that youl see the control in the right hand corner unplug the old replug the new . DISCONNECT POWER PRIOR TO REPAIR<
Posted on Oct 27, 2008
  • 400 Answers
SOURCE: Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Posted on Mar 20, 2009
I have a Maytag side by side, MSD2434GEW, about 8 years old, the fridge side appears to be working fine, the freezer side is about the same temp as the fridge and not cold enough to freeze anything. It...
the clicking sound is the compressor trying to start . i belive that you need to reolace the relay start on the compressor . the part that maytag has on ther websight is 12002794 about 34.00 .. mm hope this helps feed back pls ..
Dec 03, 2010 | Maytag MSD2434GE Side by Side Refrigerator
WMSD2756GES Clicking, slight burnt smell, humming then repeats
Replace the overload relays down at the compressor. Easy repair and too expensive. Do this and you'll be good to go.
Feb 01, 2010 | Maytag MSD2756GES Side by Side...
Fridge working but not cooling.
The white component you see , is the problem . That is the overload/relay . These short due to power surges , dirty coils in the front bottom of refrig , or just by age . They short , to save the compressor , when one of these happens . The part number you need is # 8201786 . This part just prys off (maybe one wire clip ) , easily replaceable with instructions included with the part .
Sep 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Clicking, buzzing, compressor too hot, thawed out
Sounds like the compressor is in thermal overload. Let it cool down completely and meter the starting amperage on start to run. The compressor could be seized or it's windings could be shorted to ground (checking the resistance between the windings terminals on the compressor while unplugged will determine this.).
Jul 14, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
My freezer in my side by side Maytag Refridgerator is not keeping food cold -everythings melting -ice in ice maker is melting - motor is running but making periodic clicking sounds.
turn the unit off at the motor/compressor is over heating hence the clicking noise when it cuts out. Defrost it with both doors open for 48 hours. then try it again.
Mar 27, 2009 | Refrigerators
My amana bottom freezer refrigerator is making a periodic clicking sound. Only to find out the items in our freezer have defrosted! Any idea why?
The periodic clicking sound you hear is probably the overload protection device that is on the compressor, what makes this clicking sound is that it is overheating causing the bi-metal to open, now what causes the bi-metal to over heat. check your condenser or condenser fan they should both be clean and operating, make sure your that the back of the refrigerator is at leash 6" away from any wall, if not this will prevent air flow to the condenser which will cause it to overheat.
Feb 25, 2009 | Amana ABB1927DE Bottom Freezer...
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Noisy compressor
If it's a buzzing for a few seconds followed by a click, your probably going to need a compressor. This sounds like that problem. Check your warranty. Many manufacturers went to 1 year on this in '06.
Nov 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool gd25sfxhs03
That click maybe you compressor cycling on its overload pertector... see if compressor is evern running..listen for a click there  .it maybe a bad relay on compressor
Oct 31, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
