Question about ASUS Intel 815E Chipset CUSL2-C Motherboard
When i go to install OS, it shows that bios isn't acpi compliant
When i want to install OS, it shows that bios is not acpi compliant. thats y need to update bios
  • 81 Answers
This errror coming from motherboard because your BIOS version is different as compare with new version, so download new BIOS for ASUS Intel 815E Chipset CUSL2-C from web site of ASUS there is detailed step of How to upgrade BIOS, you can upgrade BIOS by creating Bootble Disc otherwise you can Upgrade from OS.
I hope that this has been very helpful for you
Posted on Dec 12, 2009
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
Dec 30, 2009 | Dell Dimension 8300 PC Desktop
Hello, I can't install my os it says the BIOS is not ACPI compliant. What to do?
Check the computer manufacturer's website for a flash BIOS update. ACPI is an onboard power management program that works with the OS to turn devices on the motherboard on and off as needed in order to conserve power. Modern OSs require this function to operate correctly. The update will come with instructions for installing it, and you must follow them exactly, else your computer may become unusable.
If no update is available, you'll have to revert to the original OS to use it, as there is no way around this that I've heard about. ACPI has been standard on PCs for over 10 years, and it's unlikely that any modern OS will work on a PC without it.
Oct 27, 2009 | ASUS F80Q-X2AM Notebook
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
ACPI BIOS not fully compliant
w8000 a very old PC not supported by HP.
windows 2000 support ended like 15 years ago.. W2k. is gone. w2k only runs on very old pcs with very old ACPI
(power controls is that)
this PC is only supported with XP
never 2000.
HP tells you that if you looked.
park the 2000 disk or use it as frezzbee. IMO
https://support.hp.com/us-en/drivers/selfservice/compaq-evo-workstation-w8000/322279
id get w7 disk and use that, it might work.
but will cost you a license from MS,
about 5 times the value of w8000
why not just go here, and get used $20 w7 pc
save a bundle of case and grief messing with any legacy junk....avoid legacy junk and win.
http://www.pcdied.com/cheaper.html
a usa answers.... always...
Jul 19, 2017 | Compaq Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
I have ACPI problem. said when i was trying to install os on my system and it said "the bios in this system is not fully ACPI compliant" pls what can i do
For that particular software you are using,,the ACPI thinks your Bios needs updating.
You can re flash the Bios to a newer version if one is available, and if one isn't available,,then i would suggest turning off the ACPI functions in your system Bios.
ACPI controls the power saving features of your machine via the software, also the power saving features on any legacy devices attached to your system.
Jan 19, 2009 | Computers & Internet
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
ASUS Intel 815E Chipset CUSL2-C Motherboard Logo
163 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
