Question about Motorola Mobility RAZR V3m Cellular Phone
External keys locked. Can receive calls, can't
External keys locked. Can receive calls, can't access menu, call out, or shut off.
Car battery flat stopping entry to car using key fob no external lock to allow access using key how can I gain entry to car.
I've never heard of a car without at least a key lock on the driver door. Unless it's a custom car, but they usually have a hidden button to push to open the doors. The only way to get in, other than calling a locksmith or breaking a window, is to use a "burglar bar", or as some call it, a "slim jim", to try and hook the opening or door lock mechanisms inside the door.
Jan 08, 2011 | Mercedes-Benz SLK Cars & Trucks
Panasonic cordless phone model KX TG 5771 dial got locked. Password in not known. we can receive calls and we can talk also. we can not dial the numbers.
My cord less Panasonic phone dial locked not able to dial please give solution how to normalise the dial lock.
Dec 08, 2010 | Panasonic Lands Phones
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
To activate automatic keylock:
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
Need to unlock a Nokia 6103b
Unlock your phone
  • Press Menu, enter the lock code, then press OK.
Answering a call when the phone is locked
  • Press Answer.
To change the lock code of your phone
Your phone's lock code is used to lock and unlock your phone.
The default lock code is 1234.
  1. Use Menu 4-3-2-3 (Settings - Security settings - Access Codes - Change lock code) to change the lock code.
  2. When the phone requires the lock code, it displays "Enter lock code:".
  3. Enter the code, then press OK.
If you enter a wrong lock code five times in succession, your phone prompts you for the security code.
Saving the unlocked phone number
Use Menu 4-3-2-2 (Settings - Security - Settings - Unlocked phone number) to save a number that may be called even when your phone is locked. You will be required to enter the lock code.
  1. Calling the unlocked phone number.
  2. Press the Up or Down arrow keys or or manually enter the number exactly as it is saved, then press Call.
Note: The More key will pause the automatic scrolling of the help text. Pressing the More key or the Up or Down arrow keys will toggle through the pages. The More key is only displayed when the help text is displayed.
Jan 26, 2009 | Nokia 6103 Cellular Phone
Lock the keypad
K800i To manually lock the keypad:
  2. Select "Lock keys".
  1. From standby, select "Menu" > Settings.
  2. Select "Unlock".
  3. hope this helps Thanks and God bless
Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
SAMSUNG SLIDE SHUT/LOCK
If it's the SGH-D900i phone that you have... Go to Menu... Settings.... Phone settings... Slide Settings... in there you have to change the "Down" from 'Continue operation' to 'stop operation'... save and slide the phone shut, that should once again lock the keypad.
Jun 10, 2008 | Samsung SGH-D900 Cellular Phone
Deleting all calls...
The calls are automatically saved but you can lock the access to the call list if you want. Look in the security menu. Menu, Settings, Security, App lock.
Apr 26, 2008 | Motorola Mobility RAZR V3
Missed calls
How do I view the numbers of calls made or received? space.gif space.gif answer.gif You can view the last ten calls that have been placed and the last ten calls which have been received in the Recent Calls option menu.
  • Press the Menu, Recent Calls and press the right soft key to select.
  • To view the calls you have received scroll to Received Calls and press the right soft key to select.
  • To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
  • Once in the Received or Dialed calls you can get more information such as the time the phone call was received/dialed by highlighting the call you want to view, and press the right soft key to view.
  • Scroll down to view all the available information.
In order to delete a received, or dialed call simply highlight the call you want to delete, press Menu and then select Delete. You can delete all the calls in the chosen section by selecting Delete All instead of just delete.
Mar 13, 2008 | Motorola Mobility RAZR V3
Motorola V3
you need to replace the old felx cable with a new one....if you know how to remove it, you can do it yourself or take it to a certify technican to do it for you.
Dec 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
