Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Reddy heater 60000 btu kerosine heater
Wont stay running, Blows a cloud of smoke and dies
  • 288 Answers
It either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Posted on Dec 19, 2009
Honda gx620 on golf cart occasionally bogs down & blows enormous cloud of white smoke from exhaust.gas getting in oil also.runs great until this happens
What ussually causes white smoke to come out the exhaust is oil being sucked up in carb. Typical causes are too much oil in crank case or PVC valve. Or really bad piston rings
Feb 26, 2014 | V-Twin Horizontal OHV Engine with Electric...
My 95 s-10 4.3L seems to run good but when it's
Blues smoke is Oil. sounds like the old girl has some high mileage on it.
When was the last time the Plugs Rotor and Cap were changed?
Jul 07, 2013 | Cars & Trucks
Engines idle goes up and down after warming up and blows blue smoke
If the engine idles for a while then blows blue smoke this is an indication of oil passing the valve stem seals and being burnt in the combustion process. ( When you are at lights and they change and you accelerate away leacing a cloud of blue smoke this is worn valve guides and failed valve stem seals) As for the idle it could be the oxygen sensor is coated with oil and soot and is malfunctioning henace the cpu cannot regulate the fuel setting correctly. Have the valve seals replaced and clean the Oxygen sensor and check for other fault codes
Feb 17, 2013 | Cars & Trucks
Every now then blows out a cloud of white smoke.it doesnt use oil and water stays full.
When engines are cold you can see water vapor as "white smoke" coming out of the tail pipe. If an automatic ... you may be burning some ATF.
Jan 18, 2011 | 1994 Toyota Pickup
Starts and quits puff of smoke comes out 60000 btu
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 16, 2011 | Heating & Cooling
My 2007 Sorento is a 2.5 diesel and has all scheduled service by the Kia dealer. Its done 25,000km goes well in all respects but after being parked for 8 hours it blows a huge cloud of blue smoke on start...
blue smoke would show a lean condition. most likely a fuel line leak between pump and tank not a pressure leak.or a check valve is allowing fuel to run back to the tank
Mar 20, 2010 | 2007 Kia Sorento 4x4
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Ready heater sparks and theen just blows smoke
Make sure the fuel is not contaminated,and is k 1 ,if it is diesel fuel in it,and it is not made for diesel ,then that is the problem,also use a anti gel additive for gelling in the fuel,it doesn`t have to be that cool for gelling.
Jan 08, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
508 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Matt Olenzek
Matt Olenzek
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
