Question about Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Faulty plate warmer on rangemaster 110 dual fuel
After just 10 months my ceramic electric plate warmer has stopped working. The neon lights up and all the other electrics are fine, but the plate warmer just won't heat up. Can it be replaced or perhaps does it just need a fuse? Not sure if this is a big job because it looks as if the plate warmer is sealed into the cooker. please help.
  • Anonymous Oct 16, 2008
    i have the same problem toldeo 100 only 12 months old hardly used and the warmer plate does not work even though the neon comes on
  • devlock25
    devlock25 Jun 07, 2012
    I am now waiting for my 3rd replacement plate warmer in 6 years. Each time the wire from it disconnects and shorts out on the frame. MUST be a design fault, using the wrong solder type.
Yep, Ive had the same problem. 3 plates in 3 years.
The wiring just falls off the connecter that feeds the heating element.
Must be a design flault. Aftfter 4 years its now out of warranty so i,ve just
left it unfixed.
Posted on Oct 14, 2012
We have the same problem on a Rangemaster Toledo 110. It is not a fuse.
The 'Hot' light still comes on because that is a different (parallel) circuit.
Examination by a competent electrician has found that the soldering for the wires that power the warming metal strip under the glass is faulty. You will have to ask for a replacement part.
There may be a design flaw, so you might want to enquire about the professional all gas burner top and just use the griddle as a warming plate over the second wok burner.
Good luck.
Posted on Feb 21, 2008
    New Friend:
Our 2008 model failed the same way after 5 years, but the replacement from http://www.espares.co.uk/part/cookers-and-hobs/rangemaster/toledo-110-df%2fng-silver-%28/p/1092/2322/0/1442018/1445583/right-hand-hob-assembly.html has a new design which I am optimistic about - see the second photo on that page. They have soldered substantial tags to a metal-plated section of the glass. This may give anyone else who finds this old thread (as I did) the confidence to buy a replacement - I wasn't going to pay for one with the old design.
Posted on Mar 07, 2013
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
Jan 19, 2016 | Rangemaster Range Cookers Kitchener 110...
Rangemaster victorians deluxe, double oven , duel fuel
Is there any sort of fan in there - could be some blades hitting surrounding.
Sep 14, 2017 | Rangemaster 110 (Dual Fuel) Dual Fuel...
The plate warmer will not work tonight. Everything else seems OK. I've tried turning the appliance off at the mains and then back on again, but it didn't work
Hi
I have just had the same problem, the connections just fall off the heater! Waiting for a response from Rangemaster....
cloudbase50
Dec 02, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Cant find serial number of rangemaster 110
It should be on a plate on the right hand side of the range at the bottom under the pan drawer.
Nov 05, 2009 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
May 08, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Rangemaster 110
it is not at all obvious.
from memory, there are 2 screws on the lhs side of the plate which remove and the plate will then move sideways but may be difficult to shift
Nov 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Gas oven operation
spark should stop when burner is lit.clean the probe with a light sandpaper and see if this corrects it.
Sep 24, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Oven fan noisy/broken
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Sep 24, 2007 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
1,951 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
