Question about GE Advantium 120 Convection/Microwave Oven
Strang Metal flapping noise
Just installed a new Advantium 120. Plugged in, fine. Set the clock and the weird noises start. It sound like a metal flap moving in the top. I thought it might be ccalibrating itself, but after 2 hours decided it must be something more. Anyone else have this issue?
  • GE Master
  • 9,098 Answers
Is it like the sound in the video?
If so, it may be a bad damper control switch or the damper assembly may be binding.
If it's new, then it should be fully covered under warranty and GE should send a servicer out at no charge. GE Customer Service is here.
If it is not under warranty, then w
e have the service manual for this model and have uploaded it for you here.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 13, 2009
GE advantium 120 convection Cafe microwave making rythmic sound when plugged in and not running. Is coming from the right side of oven Any ideas what it is and how it can be fixed?
The only cause of clunking I can think of is the turntable motor not engaging the drive spindle of the platter properly. Remove the platter and see if the noise goes away.
Nov 03, 2017 | GE Microwave Ovens
Tip
How To Change The Bulb In An Advantium 900 Watt Microwave
<span>You'll need to open the door, and remove the screws that hold the microwave face to the cabinet face.<br />Next, you'll need to remove the microwave from the enclosure. Remove the metal shroud that encases the microwave, and the bulb may then be replaced. Reversing the process gets you back to where you started.<br />After the second time of pulling the microwave out, I measured and cut a hole in the sheet metal shroud, larger than the access to the light fixture. I bought a metal electrical box cover, and used sheet metal screws to completely cover the hole. This allows me to slide the microwave out about 6" to access the light, instead of the lengthy process of removing the microwave entirely. If you decide to do this, I recommend that you mark the sheet metal while the shroud is loosely fit on the microwave, and cutting your hole away from the microwave, to avoid getting metal filings into the microwave.<br />Your bulb is a 120 volt halogen, 35 watts with a GY8.6 base. I bought mine at Lowe's, and their item number is 15797, manufactured for Bright Effects. When installing the new bulb, be careful not to touch the bulb, as the oil on your fingers is enough to degrade the bulb, and it will not last as long as it should. Instead, wrap the bulb in toilet paper or a paper towel, leaving the terminals on the base protruding.<br />Sorry for the bad news, but glad that I could offer a better alternative. By the way, a technician will do the same thing, without the hole, for about $200.</span>
on Apr 07, 2011 | GE Advantium 120 Convection/Microwave Oven
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
Jun 13, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Microwave oven started to make noise and heating up.
    Sounds like your microprocessor is shot and you need a new control board. Not that expensive. Try www.repairclinic.com. Let me know how you make out.
    hardrocko
    Feb 10, 2010 | GE Advantium 120 Convection/Microwave Oven
    Clicking noise whem door is closed
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    Otherwise, see this video for help.
    Feb 09, 2009 | GE Advantium 120 Convection/Microwave Oven
    Arcing
    My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
    Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
    Black Metal Tray for GE Advantium Oven
    I just found one for $33.95
    http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=SCA1001FSS001&page=3
    Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
    Noise of microwave exhaust fan
    You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
    Mar 25, 2008 | Microwave Ovens
    GE Advantium 120 Convection/Microwave Oven Logo
    122 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
