Question about Whirlpool 24 in. ADG7540 Built-in Dishwasher
Washing cycle runs for way longer than it should
  • 25 Answers
Look at the manual for "Delime Mode".
Delime mode keeps a dishmachine in wash mode only untill deactivated.
Otherwise there is an issue with your timer.
Posted on Dec 12, 2009
My 17352 Kenmore dishwasher runs for an hour or more. Can this be adjusted?
There are wash, rinse, and dry cycles that all take time. Cycle settings allow you to vary this. For example, potscrubber mode will take longer than normal wash. You can opt for no heat drying to shorten the cycle, but then the dishes will be wet and can have possible spotting. Experiment with the controls and find the settings that give you the results you want in the least amount of time. But just FYI, an hour isn't that long for a dishwasher to cycle - many run longer than that.
Nov 03, 2016 | Kenmore Dishwashers
How do I fix my washing machine? It doesn't appear to feed enough water into the machine. The machine runs through a full cycle but appears low on water even in the middle of a full wash cycle.
I can try to explain the difference between today and the old washing machine. My question would be, are you satisfied with the washing result? If so, then everything is fine.
There are four factors that affect the washing and they make one single round (duration, temperature, mechanical action, chemical action). Old washing machines are spending more water, more detergents, more electricity power, and consequently more spoiled environment and duration of washing was app. from 1 to 1.5 hours. Today washers use less water, less detergent, less energy power, less polluting but because longer duration of washing cycle app. from 2 to 3 hours, wash result was the same as in the old machine.
I think that today confuses people how is possible that washing machine wash three hours (longer than before) and consumes less energy? Believe me this is true, and every service tehnician will explain it.
Because old habits many customers put the same amount of detergent (do not read the manufacturer's instructions) and therefore have problems with the skin. That is why an increasing number of washing machine has the option of additional rinsing cycles.
Dado
Jul 23, 2015 | Bosch Washing Machines
How long should it take to run a clean washing cycle
On the high efficiency machines it takes longer, because of the amount of water used. It takes a few more cycles to complete.
Mar 04, 2015 | Maytag Bravos XL High-Efficiency Electric...
Samsung WF209ANW washer spins excessively and loud. Runs longer than time on cycle
I think you should call a technician and i am guessing has reach the end of its life :)
Jul 29, 2014 | Samsung WF209ANW 40 cu. ft. Front Load...
The dishwasher continues on the wash cycle for hours, even when I choose the "light" wash cycle
Hello, Thank You for using FixYa. I will be helping you today.Normal cycles on new dishwashers is an average of two hours and opening the door makes it longer.Also if the water temp coming into the unit is not hot enough it takes even longer because now it has to heat the water.Yes new dishwashers can take a very long time to run a cycle.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Whirlpool Dishwashers
My washing fills and drains properly, but will not agitate or run the spin cycle. I sounds like it is going through the cycle properly, but will not turn the drum (spin cycle) or agitator.
Try picking a different wash cycle, instead of your annual quick wash cycle opt for the longer wash cycle and then you may find that the spin cycle may kick-in, hope this works for you, good luck!
Apr 17, 2011 | GE WBSR3140DW Top Load Washer
I start the wash cycle timer reads 1:02 machine runs and timer counts down to 54 mins. then resets to 1:12 mins. which inturn adds approx. 18-20 mins to wash cycle why the reset??
I had a similar problem with ours and had a repair guy come out and look at it. He suggested running a couple of heavy bleach cycles through the machine. He said that sometimes if you use too much detergent (especially if you're not using the "High Efficiency" type of detergent) detergent builds up on a sensor in the machine and causes longer than necessary wash cycles. We actually ran 2 cycles of bleach and then a couple more with no bleach or detergent and the problem cleared up.
May 02, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
LG LDF6810ST Stainless Built In Dishwasher
It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
Hope this helps. Please resply with your findings. Thanks!
Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
Taking longer and longer to wash
MAKE SURE THAT YOU ARE USING A COLD CYCLE AND NOT A HOT ONE ALSO MAKE SURE THE MACHINE IS NOT PROGRAMED TO DO EXTRA RINSES.IF ALL THATS OK IF THE MACHINE HAS A ELECTRONIC BOARD THAT CAN ALSO CAUSE IT IN THAT CASE YOU NEED THE ASSISTANCE OF A TECHNICIAN.GOODLUCK.MOHAMED
Sep 06, 2008 | Fisher and Paykel IWL12 Top Load Washer
Agitator
try putting a new coupler in it
Mar 19, 2008 | Kenmore 20722
Dishwashers Logo
172 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
