Question about Garden
Low voltage lighting, The lights come on to early with the light sensor sometimes when its cloudy they come on
  • 43,501 Answers
Try to face the sensor towrds the afternoon sun to give it as much light aspossible...
heatman101
Posted on Aug 27, 2010
5.0L won't start without a shot of starter fluid
There are several ways to test the injectors. A test light called a "noid" tester connects to the electric injector plug and will light up with each signal to fire or a multi-tester set to DC voltage. Some parts chains loan tools and may have a "noid" tester.
Sometimes a crankshaft position sensor will malfunction at low rpm and work once the engine turns over well. That sensor regulates the fuel pressure for the RPM so it may be that the sensor is failing to release enough fuel at low RPM.
Sep 06, 2017 | Lincoln Cars & Trucks
Multifunction Switch Short in Pontiac Grand Prix
Do you know how to do automotive electrical testing , checking B+ power and ground circuits , using voltage drop ? Do you know how to read a wiring diagram ? Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Electric Testing Techniques You Need to Know
How to read an electrical diagram Lesson 1
http://www.bbbind.com/free_tsb.html find wiring diagrams here !
The day time running lights module , ambient light sensor , would be a good guess but that's all it would be .Do you know what these are ? Really don't think there is a short in the multifunction switch . Maybe it's time to take to a qualified repair shop , dealer ! Cadillac or Buick .
Daytime Running Lamps (DRL)
The Daytime Running Lamps (DRL) control module is designed to automatically operate the exterior lights depending on the outside light conditions.
The DRL control module operates in 2 modes:
• The day mode
In the day mode, the DRL control module turns ON the low beam headlamps at a reduced intensity when the DRL ambient light sensor detects daylight under the following conditions:
- The ignition switch is in the RUN position.
- The headlamps are OFF.
- The park brake is OFF.
• The low light mode
In the low light mode, the DRL ambient light sensor detects darkness, turning ON the low beam headlamps to full intensity through CKT 10.
Additionally, the DRL ambient light sensor turns ON the following lamps through CKT 9:
- The park lamps
- The side marker lamps
- The license lamps
- The tail lamps
Mar 25, 2017 | 1998 Pontiac Grand Prix
Low voltage oxygen sensor (upstream).
This code does not mean to replace the sensor , testing is what is suppose to happen .
P0131 O2 Sensor Circuit Low Voltage Bank 1 Sensor 1
Honda Civic P0131 02 Sensor Diagnosis
Dec 06, 2017 | 2000 Buick Century
I have a ML121RT Low Voltage 121-Watt Power Pack with Timer hooked up with three 20 watt lights attached - going north. I want to add one more 20w llight going south. Can I attach an additional wire to...
Try it... should work
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
However minimum load for ML121 is 80% load rating.. so 80 watts is ok for 100 watt transformer... 60 watts is low and can cause early failure of transformer.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 14, 2011 | Malibu Intermatic Inc. ML121RT Low...
Check engine light low voltage o2 sensor 04 chevy ventura
your code must be P0131, a P0131 code refers to the first oxygen sensor on Bank 1. P0131 means the O2 oxygen sensor's voltage remained low for longer than 2 minutes. This is interpreted by the ECM as a low voltage condition and sets the MIL. Bank 1 Sensor 1 is located in front of the catalytic converter.
The solution is you can:
1.Replace faulty sensor.
2.Repair short, open, or high resistance on o2 signal circuit. FB.init("dd7d9e9681341cde77587bc6a2029f6f"); OBD-Codes.com on Facebook
Jul 02, 2011 | 2004 Chevrolet Venture Passanger
WHY IS THE SERVICE ENGINE LIGHT ON IN MY SATURN??
The Check Engine light will light when the ECU stores a trouble code.
Counting the Flashes
To retrieve trouble codes, turn the ignition key to the "on" position with the engine OFF.
The Check engine light will flash many short blinks. The total number of blinks equals the code number. For example, flash,pause, flash,flash = code 12.If more than one code is stored, the Check engine light will flash the codes in sequence (lowest to highest) with a pause between each code. The codes will repeat until the key is turned to the OFF position.
11 Transaxle codes present 12 Diagnostic check only 13 Oxygen sensor circuit 14 Coolant sensor/high temperature 15 Coolant sensor/low temperature 17 PCM fault - pull-up resistor 19 6X signal fault (92-95 models) 21 Throttle position sensor-voltage high 22 Throttle position sensor-voltage low 23 IAT circuit low 24 VSS circuit-no signal 25 IAT circuit-Temp out of high range 26 Quad driver output fault 32 EGR system fault 33 MAP sensor - voltage out of range high 34 MAP sensor - voltage out of range low 35 IAC - rpm out of range 41 Ignition control circuit-open or shorted 42 Bypass circuit - shorted or open 41/42 IC control circuit grounded/bypass open 43 Knock sensor circuit shorted or open 44 O2 sensor indicates lean condition 45 O2 sensor indicates rich condition 46 Power steeringpressure circit(91 models)open or shorted 49 High idle indicates vacuum leak 51 PCM memory error 53 System voltage error 55 A/D error 58 trans fluid temperature too high 59 Trans fluid temperature too low 66/67 A/C pressure sensor 81 ABS message fault 82 PCM internal communication fault
Mar 10, 2010 | 1992 Saturn SL2
Batt light coming on while driving
check your voltage regulater sometimes these are internal and if thats the case replace your alternator
Jan 15, 2010 | 2000 Dodge Intrepid
Low collant light is on and has no leak and is full
This problem is common, if the coolant level is OK, check the "coolant sensor" and clean the plug.
Aug 28, 2009 | 1995 Buick Park Avenue
Check engine light
Have you erased the codes after replacing the parts? Disconnecting the battery for a few seconds usually erases them, maybe it will work for you.
Nov 24, 2008 | 2004 Jeep Liberty
Garden Logo
89 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
