Question about HP Pavilion dv1227us (EA376UA) PC Notebook
Can't see anything. In the right light can barely see the desktop. Too dim for functionality. Any ideas?
  • 63 Answers
May need a new lamp light in the screen
Posted on Dec 12, 2009
What's your problem?the screen turns very dim to where you can barely see the picture
Your monitor is going bad or your video card is going bad. Try using another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and see if you can barely see the icons and desktop on it. If the borrowed monitor is bright and clear and you can see things ok, then your original monitor is going bad. If the borrowed monitor shows the same problem of barely being able to see things, then your video card in the computer is bad.
May 06, 2012 | HP Pavilion Slimline s3600t Desktop PC
Pioneer deq-7600 lcd very dim, lcd problem?
The LCD display is failing, or the driver ic is the issue, or the B+ is to low causing the dimming effect, a resistor gone high in value would explain this.
Mar 19, 2012 | Pioneer Audio Players & Recorders
On startup, goes to very dim screen
If the hard drive is going bad, usually running scan disk will help diagnose the problem. If scan disk reports bad sectors then it is likely time to replace the drive. If no bad sectors then the problem is probably somewhere else. Hopefully it is functional enough to get to scan disk.
left double click on my computer, right click on the C: drive, click properties, choose the tools tab, then choose "error checking"
Aug 09, 2009 | HP Pavilion a320n PC Desktop
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
When my computer boots up, my screen is still black!
do check the LCD brightness settings..its usually on the function keys..you press the function key and the other key at the same time there should be a icon on the keys..some laptops have the arrow buttons(up,down or right and left) for controlling brightness...hope it helps!
Oct 30, 2008 | Compaq Presario R3000Z Notebook
98 chevy express headlight/ turn signal problem
Ground problem more then likely . Looking at a wiring diagram turn signals an headlamps right front share common ground G-109 . Do you know anything about automotive electrical circuit testing ? Voltage drop testing ? Watch these videos .
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Electric Testing Techniques You Need to Know
Free wiring diagrams at http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click on lighting ,then under subsystem click on headlamps .Click the search button ,then the blue links . Look at wiring diagram so you know which wire is which . Power , ground etc...
G109
In the right side of the engine compartment, near the fender well !
Sep 02, 2017 | 1998 Chevrolet Express
Head Lights
If only the headlights are dull and not putting out the correct light, I would suspect a bad ground (earth) connection somewhere in the headlight circuit or the fuse for the headlight circuit. Something is causing excessive resistance and causing less voltage to be provided for the headlights. If all the lights are dimly lit, then I would check the charging system, the battery and the ground cable for the battery, chassis, and engine.
Jun 13, 2008 | 1995 Ford Crown Victoria
Screen went dim
I have the same problem with the same head unit except mine is new out of the box. Is this a factory defect or is it something I can fix
Oct 11, 2006 | Jensen VM9410 Car DVD Player
HP Pavilion dv1227us (EA376UA) PC Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
