Question about Sony Ericsson w580i Cellular Phone
I have SE W580i-It'bluetooth is not working, though TURNED ON & visibility ON. On bluetooth, Neither this phone is found by others NOR other cells can find my mobile. any idea to restore bluetooth settings to default e.g. by code ???
My Sony Ericsson W580i bluetooth is not working, when I go to bluetooth menu it allways show bluetooth on but actually it is not on or no bluetooth sign show on screen where is the problem help me it is...
Plugin your USB Cable and using the Sony Ericksson app on your computer, update your firmware. If you update your firmware and it STILL doesn't work, then i am afraid its the phone.
Aug 06, 2011 | AT&T Sony Ericsson W580i Cell Phone -...
Bluetooth on my cell phone does not know why. when you turn on bluetooth can not find it via another phone. Or when I'm going to send something to someone can not find any device just constantly look...
try to open your bluetooth settings whether your bluetooth is just HIDE or VISIBLE... if it is visible to other device then try to send again.... if it is invisible to other device then you cannot send to other device via bluetooth...
May 15, 2011 | LG KU250 Cellular Phone
I have a problem with my Samsung GT-S3653W, I want to send files to my sisters phone through Bluetooth but it always says no device found even though the Bluetooth of my sisters phone was already turned...
There are two possible solutions:-
1. Check that visibility of your sister's phone is either 'ON' or 'VISIBLE TO ALL'. Not sure what the exact option should be but check that 1st.
2. If this doesnt help then check whether you can send files to any other bluetooth enabled phone. Also check whether your sister's phone can receive files from other phones. This can point out the problem.
-----------------Pls rate if its useful--------------------
May 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Hello...i am using sony ericsson k550 i had a trouble in that i cant send any files through bluetooth my bluetooth is not working pls any one tell how to solve this prob
Make sure your phone and the other Bluetooth device are charged, switched on and within range of each other. Make sure Bluetooth wireless technology is turned on, and that the devices are set to be visible for other Bluetooth devices. Check that the two devices are paired, and have found each other. If there are still problems, you'll have to reset the connection and pair the two devices again.
In some Bluetooth installations, you must activate a COM port manually in your computer. This is done differently for different brands and models of Bluetooth devices. Please see the manufacturer's product documentation.
If a COM port is not activated
1. In many cases, you can right-click on your phone icon in the window where all found Bluetooth devices are shown, and select a 'COM port activation' item in the menu. Make a note of the COM port number of the activated port.
2. Open Sony Ericsson PC Suite and click Tools/Phone Monitor Options.../Com Ports. Enable the COM port you activated in step 1.
3. Keep the Bluetooth wireless technology turned on in your phone, restart the computer and try to connect again.
Feb 08, 2011 | Sony Ericsson K550i Cellular Phone
How do i disable bluetooth on my SGH A561 samsung flip phone
To disableset Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to disable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Hope that helps..
Thanks for using fixya.....
Jan 08, 2011 | Cell Phones
How to show pictures from this phone to the computer?
Use Bluetooth
Your phone is equipped with Bluetooth
technology, enabling you to connect the phone
wirelessly to your computer to exchange photos.
1. In Idle mode, press
<Menu> and select
Settings → Bluetooth →
Activation → On.
2. Select My phone’s
visibility → On to allow
other devices to find your
phone.
Turn on
Bluetooth
<Menu> and select
My devices → Search for
new devices.
2. Select a device.
3. Enter a Bluetooth PIN or the
other device’s Bluetooth
PIN, if it has one, and press
<OK>.
When the code is entered on the computer, pairing completes.
if your PC does not have bluetooth you can buy an inexpensive bluetooth usb dongle here-
http://www.amazon.co.uk/gp/product/B001BRV7JE?ie=UTF8&tag=microsift-21&linkCode=as2&camp=1634&creative=19450&creativeASIN=B001BRV7J
//javaftper
Jul 31, 2010 | Samsung SGH-X830 Cellular Phone
Trying to connect Nokia 5800 to prowave bluetooth car kit
you have to make your phone visible to other devices. to do this, go under settings, make sure bluetooth is on, then adjust the visibility of the phone Settings
Select Menu > Settings and Connectivity > Bluetooth.
When you open the application for the first time, you are asked to define a name for
your device. You can change the name later.
Select from the following:
? Bluetooth — Turn Bluetooth connectivity on or off.
? My phone's visibility — To allow your device to be found by other devices with
Bluetooth wireless technology, select Shown to all. To set a time period after which
the visibility is set from shown to hidden, select Set visibility period. To hide your
device from other devices, select Hidden.
? My phone's name — Edit the name shown to other devices with Bluetooth wireless
technology.
? Remote SIM mode — Enable or disable another device, such as a compatible car kit
accessory, to use the SIM card in your device to connect to the network
Mar 23, 2010 | Nokia 5800 XpressMusic Smartphone
Why my SE G705 bluetooth can't connect to my laptop?
actually u better use the data cable for sony ericcson becoz connecting with pc sum times is a trouble for se phones.. CHeck the discovery of ur pc bluetooth on. And clik on recieve a file option.
Aug 11, 2009 | Sony Ericsson w580i Cellular Phone
I can't prepare to connect with another device on bluetooth to send on via bluetooth
Make sure blue tooth is on (on both devices) and in range. 10 feet max. In settings menu make sure both devices are visible to other devices. When prompt, you must enter the same password on both devices.
Jun 20, 2009 | Sony Ericsson w580i Cellular Phone
How do I set up my bluetooth to my sony ericsson w580i?
MENU-SETTINGS-CONNECTIVITY-BLUETOOH-TURN IT ON - MAKE SURE IT IS SET TO VISIBILITY
Jun 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
394 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
