Question about Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome...
Moen M7800 faucet: need to remove from sink. nut stuck. want to remove the upper parts to hold & remove nut
  • 360 Answers
SOURCE: Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Posted on Feb 12, 2009
gary1121
  • 332 Answers
SOURCE: wobbly faucet on new elkay sink
this faucet comes with diffrent hold downs for diffrent sinks on is wider for stainless sinks the other is smaller for granite or corian sinks, it sounds like your plumber might have put the wrond spacer under the facet where it mounts to the sink,, it doesn't matter the sink or the faucet they all come with proper adapters, and I do know that moen and delta have them in the box with the faucet,,, good luck with yo people, this faucet of yours even comes with the plastic tool to put the faucet in because it has a long shank with threads on it and is hard to get a wrench on
Posted on Jun 07, 2009
  • 6 Answers
SOURCE: can't remove moen bathroom faucet assembly to
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Posted on Jan 03, 2010
ftw1952
  • 10319 Answers
SOURCE: moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Posted on Feb 14, 2010
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
I need help tightening a kitchen faucet to the sink.
If you look under the sink you shouls see a big nut ...all you have to do is to tighten it while holding the faucet on top at the right place
Mar 24, 2017 | Moen Plumbing
How is the cartridge removed on the faucet?
How To Repair Cartridge Sink Faucets at The Home Depot
www.homedepot.com/.../project_guide_repairing_cartri...
The Home DepotJul 22, 2013 - Quickly fix a leaky cartridge sink faucet with this detailed step-by-step ... On some models of faucet you may have to remove the cartridge with a
Removing a moen cartridge from the faucet! If the plastic tool ...? 2:47https://www.youtube.com/watch?v=vGdExIS3b-oMar 5, 2013 - Uploaded by TheOldkid888This is a video on how to remove a moen cartridge from any moen faucet when the plastic tool does not do ...Installation Help / Animated Tutorials for Moen Faucetwww.moen.com/consumer-support/installation-help/tutorial?id...MoenUsing a Philips screwdriver, unscrew the handle screw and pull the handle up off from the faucet. Using pliers, loosen and remove the pivot retainer nut as well. Remove the washer from the cartridge and use pliers to remove the retaining clip.
Dec 03, 2015 | Plumbing
How to remove moen bath faucet handle that has no set screws and is all 1 piece
1.) its not all one piece
2.) the tower threads onto the valve body, you may need to loosen the mounting nut under the sink top with a basin wrench to relieve the pressure on the handle tower
3.) this is the exploded parts view for your faucet: http://www.moen.com/shared/docs/exploded-parts-views/s498pt.pdf
4.) this is the instruction sheet for your faucet, including a technical support number you can call: http://www.moen.com/shared/docs/instruction-sheets/ins1207.pdf
Aug 26, 2014 | Moen Showhouse S498 Savvy Two Handle...
Leaky faucet
This is generally due to a loose or faulty cartridge. To fix:
1. Turn off water supply valves under sink.
2. Block the sink drain to avoid losing small parts.
3. Remove faucet handle. It is attached by a set screw, an odd size (I actually used a T9 torx screwdriver successfully, even though the set screw is hex head, since I did not have a matching allen key). The set screw is quite far into the handle, ~3cm, through a hole in the bottom of the handle. Depending on your countertop layout, you may have to actually remove the entire faucet from the countertop in order to get access to it, in which case follow the appropriate parts of your faucet installation directions in reverse.
4. Remove dome. It will come off with a gentle turn/pull.
5. Check the tightness of the exposed large hex nut. This is the piece that holds the cartridge in place. If you are lucky, it is just loose, and that's your problem; otherwise you will need a new cartridge.
6. Unscrew that nut, remove. Pull out the cartridge.
7. Replacement cartridges may be found at your local Moen dealer, or may be ordered directly from Moen +1-800-Buy-Moen. Parts are free due to the lifetime warranty. Part #1255 includes the cartridge, cartridge nut, and set screw. The nut must be changed with the cartridge (presumably due to its wear characteristics).
To reassemble:
8. If you have it, place a very small amount of plumber's silicone lubricant on the back of the cartridge, on the rubber seals around the three holes.
9. Assemble in reverse order of disassembly. The cartridge only goes in one way, due to three guiding channels on its perimeter.
Enjoy!
Oct 08, 2012 | Moen 87877SRS Haysfield Spot Resist One -...
How to remove "cover" on faucet for drain
under the sink there is a rod that screws into the back of the drain pipe right under the bowl of the sink unscrew the nut holding the rod in and the drain plunger will pull up
Sep 24, 2011 | Moen 1 Handle LavatoryWith Drain Assembly...
I have a 15 year old Moen bathfaucet 4650-P that I want to replace. I can't figure out how to remove this old faucet. It has three holes with the outer holes on 4 inch spacing. The two handles and the...
There is definitly a nut or nuts holding the faucet to the sink. It could be around the center shaft that goes through the sink, but most likely 2 small nuts that screw onto the 2 outer stubs. These are your hot and cold wated supplies. crawl underneath the cabinets and check. It might be difficult to get them off, but they do make a pipe wrench tool that has a rotating head that makes this easier
Mar 04, 2011 | Moen Home
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Moen faucet removal
Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
1,415 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
